a/c relay
Old Sep 10, 2005 | 03:16 PM
phoshizzle88's Avatar
Default a/c relay
ok my a/c stoppd working the other day. so i went to get the freon refilled. once they refilld it the compressor wouldnt kick on. so the guy bypassed it and ran it straight from the battery. he told me i had an electrical problem. im thinkin its the a/c relay does anyone know where it is and its for a 92 prelude SI
Old Sep 10, 2005 | 03:31 PM
92hondalude's Avatar
Default Re: a/c relay (phoshizzle88)
helms says
A/C compressor Clutch realay - Left side of engine compartment
try that
Old Sep 10, 2005 | 03:42 PM
Default Re: a/c relay (92hondalude)
got a pic?
Old Sep 10, 2005 | 04:10 PM
bump any other opinions?
Old Sep 10, 2005 | 06:29 PM
onefastrx7turbo's Avatar
try shorting the A/c compressor manually. do this by connecting the A/C pump wire to a 12v source. you can do it with the car running or not. if its not running, you'll hear a loud click. if it is running, you'll see the clutch engage. if it works, then see if its the relay. if the relay checks good, it might be your low pressure switch.
neil
Old Sep 10, 2005 | 09:02 PM
Default Re: a/c relay (onefastrx7turbo)
ok i tried it and it engages. changed the relays and still nothing. where is the low pressure switch at?
Old Sep 10, 2005 | 09:10 PM
bump any help i want my a/c back. lol thnx
Old Sep 10, 2005 | 09:12 PM
Lewdin' Incognito's Avatar
I just fixed mine today by re-soldering the connections on the climate control circuit board in the dash. Thought I needed a new accumulator, but just turns out that it was losing the electrical connection on the board. If your lights on the climate control buttons flicker or don't come on at all, or if you have trouble swithcing the air flow buttons, you might want to look into that.
Old Sep 10, 2005 | 09:16 PM
Default Re: a/c relay (Lewdin' Incognito)
nope the light is bright green
Old Sep 10, 2005 | 09:18 PM
Fongman's Avatar
yep, my car did the same thing. I just bypass the on switch, and made my own switch. you would have to know the color. let me know if you still can fix it i will like at my car and tell you the two wire color to jump the together.
Old Sep 10, 2005 | 09:24 PM
Default Re: a/c relay (Fongman)
howd you make your own switch gotta pic of it?
Old Sep 10, 2005 | 09:47 PM
bump
Old Sep 10, 2005 | 11:33 PM
anyone else
Old Sep 10, 2005 | 11:41 PM
pm'ed you
neil
Old Sep 11, 2005 | 09:29 AM
bump anyone else?
Old Sep 11, 2005 | 09:39 AM
wstef's Avatar
I had the same issue in my car.
It was a broken wire between AC pressure sensor and AC thermostat.
In my case the wire has broken about 15 cm (so 7 inch ) on the left from AC pressure switch.
The same story my buddy had in his civic.......
So first check the continuity between AC pressure switch and AC thermostat (it is the blue-yellow wire).
The AC pressure switch is on the left down side of AC condenser, you can access it by the bumper hole, and the AC thermostat is stright before passenger legs, on the evaporator box. You will need to remove the glove box panel to get a better access.
Old Sep 11, 2005 | 02:26 PM
Default Re: a/c relay (wstef)
aight i'll try that tomorow
Old Sep 11, 2005 | 07:03 PM
ok when i first start the car now the a/c will run for a little bit. but after a little bit of driving it turns off.
Old Sep 11, 2005 | 08:13 PM
any opinions
Old Sep 12, 2005 | 09:51 AM
kinda sounds like they didnt charge the system right. the low pressure switch keeps the pump from burning out.
neil
Old Sep 12, 2005 | 12:06 PM
hmm i jus had it recharged couple days ago it was wrokin fine for a while
Old Sep 12, 2005 | 12:44 PM
Behind the passenger-side headlight (right in front of the intake filter if you have an "ebay pipe"), there is a sightglass on your a/c lines. Turn on the a/c and watch that sightglass (works better to shine flashlight on it). If you can see air bubbles going by while the system is on then it wasn't fully charged/charged correctly.
denb23
Oct 30, 2019 08:11 PM
Blimp53
Honda Civic (2006 - 2015)
Jun 30, 2015 05:48 AM
vanser3004
Honda Civic (2001 - 2005)
May 31, 2010 04:46 PM
8_UR_AWD
May 15, 2009 10:05 PM
turbob16ef
Jan 11, 2006 03:47 PM
