VTEC problems
Old Sep 12, 2005 | 09:12 PM
'97ludetuner's Avatar
Default VTECH problems
I have a '97 prelude. For some reason my VTECH will either not work or is late and not as powerful (was kicking in at 4Krpm and now 5500 rpm again, if at all now) Any help? thanks
Old Sep 12, 2005 | 09:19 PM
99_SH's Avatar
Default Re: VTECH problems ('97ludetuner)
Depending on condiditons, vtec usually kicks over around 5400RPM. The first noise you hear are the secondary butterflys opening around 4700 IIRC.
btw, its VTEC not VTECH
pheurton-skeurto's Avatar
5500 rpm is around the normal VTEC (no H) crossover point. 4000 rpms is entirely too low for engagement. you also need to be WAY more specific with your problem. if you expect someone to help you diagnose your problem over the internet you have to give them tons of info: mods, miles, previous problems, transmission, etc.
Old Sep 13, 2005 | 12:27 PM
steveobb4's Avatar
Default Re: (pheurton-skeurto)
Do you let your car warm up before you try to engage vtec????????????????
Old Sep 13, 2005 | 07:13 PM
Default Re: 99_sh, pheurton-skeurto
lets clear some things up. first, sorry to put an H in VTEC. second, the secondary butterflys opening now makes sense and no the VTEC didn't/doesn't kick at 4k rpm. Now that i am done being a moreon, the car is base, I only have an AEM cold air intake, it does have 120k miles on it (but I bought it with the intention of a a rebuild or droping in a new motor, waiting till after winter). I do have a suspition the VTEC controler was tamperd with at one point befor I bought it and joe shmoe cob jobed it when "fixing" it but I'm not sure. But i have noted that it does seem to work better (but not as good as befor) after I have been driving it for a while. when it does finaly kick in it is still at 6k rpm not the normal 5400 ie: still late and not as much power. So are there any ideas?
Modified by '97ludetuner at 8:25 PM 9/13/2005
willem
16
Feb 19, 2012 04:07 AM
fryman
Sep 28, 2008 02:32 PM
lmiguelvv
Oct 19, 2004 06:55 PM
AamirCWITR
Oct 17, 2003 09:39 AM
