jack stands....
Old Sep 9, 2005 | 12:14 PM
Jordans95si's Avatar
Default jack stands....
ii know this is a stupid question, but where do think the best place to jack/put a jackstand on a 4th gen is, i just don't wanna be messin up something...thanks
Old Sep 9, 2005 | 12:16 PM
OEM_ASSASSIN's Avatar
jackstands - there are two arrows on your side skirts that point at two stand points, can't miss them.
Old Sep 9, 2005 | 12:17 PM
iLude's Avatar
Default Re: jack stands.... (Jordans95si)
The jacking point is behind on tow hook on the back and the on the exposed part of the frame (I'm sure there's an actual name for it, someone help out) in the front. It's easy to spot, as its not covered by the plasic shield. But be careful of the exhaust manifold, as its really close to it.
Jack stands should go right in front of the rear tires and right behind the front tires. There's a metal lip thats hard to miss.
Old Sep 9, 2005 | 12:23 PM
Default Re: jack stands.... (PreluderH22)
i see the jackstand points, but where should i jack it up on, the part of the frame that goes right infront of the header's downpipe
Old Sep 9, 2005 | 12:34 PM
The Weather Man's Avatar
I think its easy to jack the car up by the pinch welds - if not, the lower control arm would do fine.
Old Sep 9, 2005 | 12:35 PM
Lewdin' Incognito's Avatar
Jack it up on the tow hook just to the left of center under the nose.
Put jack stand behind front wheels, I think the points are right at the front edge of the doors (or a little in front). You'll see a piece of metal sticking below the side about 1/2" and it 3-4 inches long; that's what you put in the "bowl" of the top of the jackstand.
Old Sep 9, 2005 | 01:16 PM
LudeyKrus's Avatar
I use the points where the LCA's join to the frame.
Old Sep 9, 2005 | 02:25 PM
bad-monkey's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I use the points where the LCA's join to the frame.</TD></TR></TABLE>
i jack by front towhook and rear towhook, though if i need to get the rear high in the air for stuff like exhaust work, i'll use the rear subframe.
butterbeer2fd
Jun 9, 2010 02:47 PM
Frickr
Apr 29, 2008 10:03 PM
sleeptime
Oct 20, 2007 11:22 AM
G2_Fella
13
Mar 27, 2007 05:04 AM
raene
Apr 19, 2001 08:03 PM
