ATTS light!
As I was driving to work today my check engine and ATTS light came on. I wasnt pushing the car nor slamming around corners. Car made it to work fine but it makes me uneasy. Whats wrong with it? Is there anyway to reset that? Is this something I can fix or do I have to go buy a new unit? any answers are better then none, thanks
That happens pretty regularly on my 97' SH. You can pull the code and find out what the exact problem is, but it's probably nothing major. You should be able to pull the radio/clock fuse for a minute or two under the hood to make it go off.
thanks guys, i pulled the fuse and put it back. Lights are all gone so i assume everything is in the clear. If it comes up again then i would check up on this.
crxaddikt
10
Sep 13, 2014 11:47 AM
shabasoft
Aug 26, 2004 06:32 AM
