Exhuast help!
Old Sep 9, 2005 | 03:43 PM
tweakalude's Avatar
Default Exhuast help!
I'm blowin smoke like a rasta, and its all of a sudden. What could be wrong besides the muffler?
Old Sep 9, 2005 | 04:10 PM
The Weather Man's Avatar
Blowin smoke?.........what on earth do you mean - you mean the smoke that comes outa everyone's exhaust pipes????
Give us colors - conditions - mods - and tell us what you did right before it happened
Old Sep 9, 2005 | 04:17 PM
tweakalude's Avatar
Default Re: (NaptownKing)
ok, well the most I've done so far is put an injector cleaner in my gas. Thats it.
Old Sep 9, 2005 | 04:33 PM
well its going to do that for a while - the engine is cleaning out..........was it BLACK - its always fun watching it when it first comes out.........i bet your bumper is full of carbon and ****.
Old Sep 9, 2005 | 05:05 PM
tweakalude's Avatar
Default Re: Exhuast help! (tweakalude)
pure white, is there any thing I can do about it?
WHITE? hmmmmm.............
If its white - you're burning oil - i believe - could be a headgasket - or something.............
Ebay - get a headgasket for like $39 or so.........
Could be a broken ringland also
Do a leakdown and compression test........you can do a compression test y ourself by buying a kit from NAPA or something
Old Sep 9, 2005 | 07:30 PM
Lewdin' Incognito's Avatar
White smoke = oil???!!!! Maybe if you're running vegatable oil......
Burning oil is blue or black, coolant is usually white - but it could also be the cleaner you put in your gas. How much/what kind did you put in, just out of curiosity?
Just as precautionary - check your coolant and oil levels and see if either is different or if either look like tan mud. That's the quickest way to see that something is bad wrong somewhere. Hope that's not the case!
Also, spend the extra $ and get your headgasket from Honda; if that's what it turns out to be.
Old Sep 9, 2005 | 07:36 PM
92hondalude's Avatar
Default Re: (Lewdin' Incognito)
most of the time white smoke is just condensation in your pipes. dose it go away after like 30 mins of idle or driving?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NaptownKing &raquo;</TD></TR><TR><TD CLASS="quote">WHITE? hmmmmm.............
Do a leakdown and compression test........you can do a compression test y ourself by buying a kit from NAPA or something</TD></TR></TABLE>
wow way off
Old Sep 10, 2005 | 02:41 AM
tweakalude's Avatar
I used an STP cleaner, the whole bottle.
Old Sep 10, 2005 | 03:27 AM
Default Re: (tweakalude)
Did you put it in whith a full tank of gas or just whatever you had in there?
Also, check your oil and coolant - just in case.
Old Sep 10, 2005 | 10:05 AM
tweakalude's Avatar
I always put a full tank in after the injector cleaner.
Andrew14
17
Jun 17, 2010 11:08 AM
trus01d1er
Apr 27, 2009 05:35 AM
1greatEG
17
Sep 16, 2007 08:26 AM
Nuke209
Dec 18, 2005 09:28 AM
SIK IN DA HED
Mar 23, 2003 02:09 PM
