lower control arm problem
Old Sep 11, 2005 | 02:00 AM
Aznboy031's Avatar
Default lower control arm problem
i recently juss got my tires replace and a alignment check, and it turns out i need a new lower rear control arm, i was wondering if anyone has a picture or a diagram of how it looks or knows where i can get one?
Old Sep 11, 2005 | 03:43 PM
The Weather Man's Avatar
The lower control arm looks like an A............
If you look at the tire from the outside -
!! = Steering knuckle
ca - control arm upper and lower
ss = shock
Sorry man - i tried my best in describing it. Anyway, the lower control arm should be attached to the steering knuckle - and that should have the hub and rotor attached to it. And the tire should be attached to the hub. I think the steering knuckle is attached to the lower control arm via a ball joint....hope it heps.
____ sss
| |!!casasaaa
| |!! ss
|tire |!!caaaaa
Old Sep 11, 2005 | 04:01 PM
wstef's Avatar
Default Re: lower control arm problem (Aznboy031)
If the aligement is out of tolerance you don't need a new lower arm but new lower arm bushings only... No need to pay 3 times more for whole arm...
Old Sep 11, 2005 | 09:21 PM
plikit's Avatar
Default Re: lower control arm problem (wstef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wstef &raquo;</TD></TR><TR><TD CLASS="quote">If the aligement is out of tolerance you don't need a new lower arm but new lower arm bushings only... No need to pay 3 times more for whole arm... </TD></TR></TABLE>
yeah i had to replace my upper and lower control arm bushings. shop wanted $450 dollars (parts and labor) which was bullcrap. i did it myself for $45!!!!!!!!! nice polyurethane bushings made by Energy Suspension. i doubt you need the arms.. unless theyre actually bent..
Old Sep 11, 2005 | 11:12 PM
Aznboy031's Avatar
Default Re: lower control arm problem (plikit)
yea the guy told me that the arm was bent out of shape, not too much tho, he showed me the alignment and i think it was at -1.1
Cheeseng35
Dec 13, 2017 04:04 PM
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
yaughtben
Aug 28, 2007 08:56 PM
94vtirozguy
Apr 14, 2006 11:37 PM
Lee_Delso
10
Dec 31, 2004 09:51 AM
