Idle prob...odd
Old Sep 9, 2005 | 05:46 PM
Lockdown_2001's Avatar
Default Idle prob...odd
Ok.... I have a 1998 Prelude.
When I turn the wheel when the car is cold, the idle will bounce from 1000-1700 repeatedly, less and less as it warms up until the car is warm then it stops. it only does it when i turn the wheels when its cold. ie, in the morning i start the car, turn the wheel, and it starts bouncing. but if i dont, it idles normal.
I dont notice any difference when im driving. when its cold and bounces, i can drive fine. Its just an annoying thing that I hope isnt harmful.
Any Suggestions?
Also, a knock when I let the clutch out all the way, when it engages. Or if i slow down suddenly in a low gear.
Old Sep 9, 2005 | 07:40 PM
92hondalude's Avatar
Default Re: Idle prob...odd (Lockdown_2001)
well when you turn the wheel in any car that has power steering it will jump up some but it should go back to normal after a secound.
a knock when you let off the clutch? hmm.... is it really loud or dose it click like your axles are goin bad?
Old Sep 9, 2005 | 08:57 PM
Default Re: Idle prob...odd (92hondalude)
the knock is as if someone knocks once on the inside of the wheel well. not like a BANG
and it goes up yes, and back down, but then it keeps doing it like its revving itself.
Old Sep 10, 2005 | 08:53 PM
anyone?
Old Sep 10, 2005 | 09:20 PM
Fongman's Avatar
check your power sterring belt maybe its losse?
Old Sep 11, 2005 | 09:14 PM
Default Re: Idle prob...odd (Fongman)
then wouldnt it keep doing it no matter what temperature the engine is?
Old Sep 12, 2005 | 08:51 PM
Fongman's Avatar
not really, did you check all your vaccum lines carefully?
jmanuel
Feb 24, 2015 04:25 AM
scythe88
Jun 14, 2010 10:13 AM
TheLastSpartan
Jul 8, 2005 10:02 PM
EK k kay
14
Jan 1, 2005 09:29 PM
cueballsi
Oct 7, 2004 11:15 AM
