Leaking Coolant
Old Feb 14, 2006 | 11:41 PM
ckur1y's Avatar
Default Leaking Coolant
Hey .. the other day i drove my car out and saw a small puddle of coolant.. what can i do to fix it... like can i patch it up? or do i have to replace it.. and can i drive with it leaking?
Old Feb 15, 2006 | 12:01 AM
onefastrx7turbo's Avatar
Default Re: Leaking Coolant (ckur1y)
where is it leaking from???
Old Feb 15, 2006 | 01:32 AM
ckur1y's Avatar
Default Re: Leaking Coolant (onefastrx7turbo)
Near the left side of the front
Old Feb 15, 2006 | 04:18 AM
The Weather Man's Avatar
probably.............the lower radiator hose? Or maybe you have a hole in the actual radiator?.....get a pressure tester and pressurize the system to expose the leaks. Or you can get that coolant dye and put it in there, then get a black light(purple?) to find out the spray pattern.
Old Feb 15, 2006 | 05:24 AM
blazefast's Avatar
did you install an intake recently? if so, it may be the bypass hose on the IM. I had a problem with a faulty screw clamp and was leaking a small amount of coolant. New clamp fixed it right away
Old Feb 15, 2006 | 07:28 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckur1y &raquo;</TD></TR><TR><TD CLASS="quote">.. and can i drive with it leaking?</TD></TR></TABLE>
Yeah, do that so that your dog or any other animal can accidentally drink it.
It's simple. Find out where it is leaking from. If you can't, take it to a shop and have them figure it out for you.
I would get under the car and see if you can see where it is leaking from. Put a piece of cardboard under the car to approximate where it is coming from. Shouldn't be hard.
Old Feb 15, 2006 | 07:48 AM
BB6racer's Avatar
hmmm...left side near the front you say? are you sure it is coolant? cause the AC is in that area and it drips water, which is normal, after you've used it. if it is coolant, and it is a hose i would say just replace it. but all the hoses are on the right side. maybe the radiator, which i would just patch up. radiators are also pretty cheap to replace if you want to though.
Old Feb 15, 2006 | 03:05 PM
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">hmmm...left side near the front you say? are you sure it is coolant? cause the AC is in that area and it drips water, which is normal, after you've used it. if it is coolant, and it is a hose i would say just replace it. but all the hoses are on the right side. maybe the radiator, which i would just patch up. radiators are also pretty cheap to replace if you want to though.</TD></TR></TABLE>
Hell yeah! Some JB Weld will clear that right up.
Old Feb 15, 2006 | 06:41 PM
ckur1y's Avatar
Default Re: (TheKINGPin)
No, i did not install a intake recently, and its not A/C cuz the stuff is green..
perpetualburn
Nov 2, 2007 10:51 AM
tigueremalo
Jul 10, 2006 07:16 PM
zumiez007
Aug 1, 2005 11:53 AM
tFUnK
Jan 2, 2003 12:56 AM
Blue teg
Dec 17, 2001 07:21 PM
