jdm head function with a usdm block?
Old Feb 22, 2006 | 11:32 AM
972drcordex's Avatar
Default jdm head function with a usdm block?
Ok so my crank on my jdm h22 is too messed up to be machined and I need a new block, and all the blocks I can find are usdm. So my question is if I transfer the pistons to the usdm block is there any reason why it wouldnt not function correctly with the jdm head? i.e. compression, clearance and anything else. Thanks again you guys are always helpful
Old Feb 22, 2006 | 03:06 PM
Default Re: jdm head function with a usdm block? (972drcordex)
anyone?
Old Feb 22, 2006 | 03:14 PM
Chuckles99SH's Avatar
I think it would work no problems. The JDM h22 is 10.6-1 vs the 10-1 compression. I am not sure if this is due to the Pistons being slightly different or thinner headgasket than the USDM one.
Old Feb 22, 2006 | 04:02 PM
CXHATCHver2.2's Avatar
Default Re: jdm head function with a usdm block? (Chuckles99SH)
the only difference between the two are the cams and the pistons, very very slight difference. They work just fine together. i have a jdm head on my usdm block and it actually feels better, crossover seems to be smoother for some reason, cant explain that one....
Old Feb 22, 2006 | 05:23 PM
Default Re: jdm head function with a usdm block? (CXHATCHver2.2)
should I just use the usdm headgasket or try to find a jdm one?
Old Feb 22, 2006 | 07:46 PM
AznBlueBoy's Avatar
the jdm head will bolt on fine.....its the exact same as the usdm one....
eg6-trans
Dec 20, 2007 12:40 AM
Tenji
May 27, 2006 03:06 AM
972drcordex
Feb 22, 2006 02:08 PM
Built2.0Lude
Mar 12, 2004 01:20 PM
