Help! Major problem.. possible cause?
Old Feb 17, 2006 | 05:14 PM
flowness's Avatar
Default Help! Major problem.. possible cause?
This problem started today suddenly, and i dont have a clue as to what could be causing it.
I have a 93 lude (non-vtec), only aftermarket parts are intake, header, and cat. Manual Transmission. I'm at about 150k miles and I believe it still has the original clutch.
Earlier today, i noticed a strange metal-sounding vibration/rattling noise when i let off the gas or shifted. Then all of a sudden, it seems like the car has no more power. When the rpms get close to or above 2k, the car lurches really violently, like a horrible shift.. even when im not shifting. Up to that point, the car feels like it has about half the power it should. It sounds really odd too, louder, and theres a noise when i accelerate that i think sounds like air rushing. It's so bad that i had trouble getting home due to even the smallest hills. It won't go over about 20mph.
This happens in every gear, and the check engine light only came on about 20 min after it started acting like this.
Any ideas as to what could be causing this?
Old Feb 17, 2006 | 05:39 PM
flowness's Avatar
Default Re: Help! Major problem.. possible cause? (silverlude15)
wow thanks for the fast response.. im so sad for my lude =[
how expensive was that fix? i know it wasnt the same car, but im just trying to get a ballpark figure so i know what im in for.. lol
thanks
Old Feb 17, 2006 | 05:54 PM
Boarderx192's Avatar
Default Re: Help! Major problem.. possible cause? (flowness)
Prob the same motor tho correct? Im not 100% sure what motors come in the non vtec. I thought it was an F22
Old Feb 17, 2006 | 06:33 PM
flowness's Avatar
Default Re: Help! Major problem.. possible cause? (Boarderx192)
yes the engine is F22B DOHC Non Vtec =]
if it is in fact the engine block, im just wondering how much roughly that would cost to fix.. parts etc..
thanks for the help guys =]
Old Feb 17, 2006 | 06:39 PM
Greg H's Avatar
tough luck man. you could do a full h22 swap for about $2000 ballpark.
Old Feb 17, 2006 | 07:26 PM
flowness's Avatar
Default Re: Help! Major problem.. possible cause? (Greg H)
ya i saw that... 2g including tranny... =[
Old Feb 17, 2006 | 08:22 PM
v4lu3s's Avatar
RTFM
putting another engine in shouldnt be too bad sicne its another lude engine and that one has been swapped already.
shakaraka
Nov 28, 2008 11:13 AM
brandobot89
Nov 3, 2007 04:04 PM
ntegraGS-R
Oct 6, 2005 04:20 AM
Fugun
Dec 31, 2004 02:33 AM
thaigsrdrv16
Aug 6, 2001 08:00 AM
