CEL 9?
Old Feb 17, 2006 | 08:08 PM
LudeCris's Avatar
Default CEL 9?
Okay I got the CEL 9 and changed the distributor thinking it was the sensor, the light went away then 2 days later it came back on same code and all! Any Ideas?
Old Feb 17, 2006 | 08:12 PM
BB6racer's Avatar
what is the "cylinder sensor"? as far as i know the only sensor in the distributor is the TDC sensor. maybe the knock sensor? can anybody help this guy out and know what the cylinder sensor is?
Old Feb 17, 2006 | 08:22 PM
98TypeSH's Avatar
Default Re: (BB6racer)
its the CYP sensor. Its located inside the dizzy housing. You need to replace the dizzy housing with a known good one or replace the entire distributor.
Old Feb 17, 2006 | 08:34 PM
LudeCris's Avatar
Default Re: (98TypeSH)
I did replace the distributor and it went away then came back.
Old Feb 17, 2006 | 09:26 PM
NeriVTEC's Avatar
Default Re: (LudeCris)
I have this same problem. Car "sputters" at idle and engine vibrates, it is throwing fuel through the exhaust, and smells like unburnt fuel. Could this be all distributor related or a bent valve problem, or maybe both??
If somebody can help us
Old Feb 18, 2006 | 08:01 PM
NeriVTEC's Avatar
Default Re: (NeriVTEC)
bumping it up for all of us
Old Feb 20, 2006 | 06:22 PM
LudeCris's Avatar
Bump still need help with this!
SIDreamer
May 2, 2011 09:51 AM
Holistic28
Honda CR-V & Element
Apr 4, 2011 09:52 AM
AnonymousTeg
Mar 15, 2011 08:35 PM
kumar*
Aug 28, 2007 09:25 AM
djtony5
Feb 20, 2003 10:09 PM
