Help, door is stuck!
Old Feb 15, 2006 | 07:57 PM
rufridn's Avatar
Default Help, door is stuck!
The passenger door is stuck. I tried to open it from the inside and outside with no luck. I hit it and it won't budge. I think the latch came loose inside
Any ideas to open it? btw, 5th gen.
Thanks
Old Feb 15, 2006 | 07:58 PM
Greg H's Avatar
Default Re: Help, door is stuck! (rufridn)
Damn that sucks! Never heard of that. Sorry man
Old Feb 15, 2006 | 08:09 PM
97 Sleeper's Avatar
Default Re: Help, door is stuck! (Greg H)
yea same thing happened to me but with the driver door but i was able to open the door from the outside....i took the door panel off and it appeared that this little plastik piece was broken...with luck my friend had an extra one...but if u say it wont open at all the best of luck to u gettin that panel off
Old Feb 16, 2006 | 12:02 PM
RemerLex11's Avatar
Default Re: Help, door is stuck! (97 Sleeper)
id say take the paneling off and look for something broken, and if that doesn't work see my above response
Old Feb 16, 2006 | 12:58 PM
rufridn's Avatar
How do you take the panel off with the door closed?
Old Feb 16, 2006 | 01:39 PM
EOE's Avatar
EOE
Default Re: (rufridn)
I know on 4th gen you can pop the plastick piece that surrounds the handle that you pull on and you will be able to push or pull on the rod to open/close the door.
That little plastic piece he is talking about is roughly 4 dollars. It's hard to explain damn.
Old Feb 16, 2006 | 02:19 PM
jeffroh22vtec's Avatar
there is some sercuity thread i remeber reading about the passenger doors on 4th gens i think it relates to the same thing with the plastic peice around the door handle
Old Feb 16, 2006 | 04:03 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Help, door is stuck! (robGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robGs-R &raquo;</TD></TR><TR><TD CLASS="quote">kick it open u ******* homo</TD></TR></TABLE>
Someone should kick you in the mouth...
EOE's Avatar
EOE
That'll work... we have a genius over here.... lol
But anyways...
Let me see if I can find any info on this.
Old Feb 16, 2006 | 04:31 PM
The_Sober's Avatar
Default Re: Help, door is stuck! (EOE)
on the bright side...at least it's the passenger side, and at least it's stuck closed rather than stuck wide open
Old Feb 16, 2006 | 09:37 PM
robGs-R's Avatar
Default Re: Help, door is stuck! (The_Sober)
i still say kick it open from the inside
Old Feb 17, 2006 | 05:29 AM
uneek4dr's Avatar
If a door could be kicked open by a person from inside the car I dont think I would want to be riding in that car. Do you have any clue as to what you are talking about? I want to see you kick the door hard enough to either bend/break the latch in the door or break the metal piece that sticks out of the car that the door latches to.. idiot
As for the problem.....I have no clue on how to open it.....have you tried what they said above about taking off the door latch cover and trying to open it by pulling the metal rod?
Old Feb 17, 2006 | 07:26 AM
rufridn's Avatar
I am going to try today.
Old Feb 17, 2006 | 07:51 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robGs-R &raquo;</TD></TR><TR><TD CLASS="quote">i still say kick it open from the inside</TD></TR></TABLE>
how about i kick you open from the inside?
i doubt the latch itself is broken, its something on the linkage, so kicking it would do zero good except hurt your leg and door panel. retard
get the door handle cover off and see if you can yank the linkage...
Old Feb 17, 2006 | 08:37 AM
EOE's Avatar
EOE
Default Re: Help, door is stuck! (mgags7)
Let us know, ill try to get the diagram for u later on today after work.
Old Feb 17, 2006 | 01:13 PM
rufridn's Avatar
I took off the handle cover and pulled the the metal bar and no luck.
Old Feb 17, 2006 | 01:30 PM
AnthonyG2003
Guest
Posts: n/a
I was thinking same thing about pulling the metal linkage behind the handle. I am sorry to hear that you can't ride the hot bitches around anymore! LoL...Hopefully you will get it soon! Keep us posted.
Old Feb 17, 2006 | 01:50 PM
EOE's Avatar
EOE
Default Re: (TheKINGPin)
Im pretty sure there isnt dude .
Take pictures of where u took the handle cover off. Or keep trying to pull on different rods, if that plastic piece we are talking about has broken off the metal bar poped out and swung down so you might not be able to see it at all. Grrr this is hard with the door panel not being off.
EDIT: Ogh and... WHAT THE HELL DID YOU DO!!!?? What, one day it didnt open or some??
Old Feb 17, 2006 | 02:40 PM
Jagan'92's Avatar
You could always leave your window down and get in Dukes of Hazzard style all the time. That would work.
just kidding.
Old Feb 17, 2006 | 03:24 PM
EOE's Avatar
EOE
Default Re: (Jagan'92)
Old Feb 19, 2006 | 01:36 PM
spoonfedcrx's Avatar
Default Re: (EOE)
DONT try yo kick ur door open!!! i see these all the time at the honda dealer i work at. i can almost guarantee u need a new latch. first things first take ur passenger seat out through the driver's side. then pull the panel off. i know its a bitch and be prepared to break it. once u get it off take the window out. u should be able to look inside the door at the latch. #3/32 in above picture. there is supposed to be a spot to drill into the latch to pop it open but i always just use an air hammer and obliterate the latch. BE CAREFUL not to blast a hole in the door. this is a very time consuming job for some, we charge anywhere from 4-6 hrs depending on vehicle so take ur time.
Old Feb 19, 2006 | 02:37 PM
rufridn's Avatar
Default Re: (spoonfedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedcrx &raquo;</TD></TR><TR><TD CLASS="quote">DONT try yo kick ur door open!!! i see these all the time at the honda dealer i work at. i can almost guarantee u need a new latch. first things first take ur passenger seat out through the driver's side. then pull the panel off. i know its a bitch and be prepared to break it. once u get it off take the window out. u should be able to look inside the door at the latch. #3/32 in above picture. there is supposed to be a spot to drill into the latch to pop it open but i always just use an air hammer and obliterate the latch. BE CAREFUL not to blast a hole in the door. this is a very time consuming job for some, we charge anywhere from 4-6 hrs depending on vehicle so take ur time.</TD></TR></TABLE>
****** expletive!
Old Feb 19, 2006 | 07:24 PM
AnthonyG2003
Guest
Posts: n/a
whoa....
Old Feb 20, 2006 | 08:06 AM
CivicSiDriver02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn &raquo;</TD></TR><TR><TD CLASS="quote">
****** expletive!</TD></TR></TABLE>
LOL
Old Feb 20, 2006 | 09:23 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn &raquo;</TD></TR><TR><TD CLASS="quote">I took off the handle cover and pulled the the metal bar and no luck. </TD></TR></TABLE>
did the bar move at all?? if it did im guessing it just jiggled loosely.....if so, take a jackhammer to your driver rear tire and then a hammer to your rear window....that should get it....lol
you will need to figure out how to get that door panel off as it sits....
