installing tachometer w/shift lite
Old Feb 19, 2006 | 11:39 AM
korney's Avatar
Default installing tachometer w/shift lite
ok I got to the signal wire, or tach wire, whatever, ok now how do I get the red to the power? can I connect to the fuse box? how can I do that? can I hook up the wire and connect to the fuse amp? is that how it is done?
can I just wrap the wire around the fuse amp and plug it back into the fuse?
Modified by korney at 5:42 PM 2/19/2006
Modified by korney at 5:45 PM 2/19/2006
Modified by korney at 5:42 PM 2/20/2006
Modified by korney at 8:13 AM 2/22/2006
Old Feb 19, 2006 | 11:43 AM
The Weather Man's Avatar
Default Re: installing tachometer w/shift lite (korney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korney &raquo;</TD></TR><TR><TD CLASS="quote">a friend of mine recived a tachometer from an another friend and my friend and I was just wondering how to install it into his 4th gen prelude, I have searched the recents and the arcived topics and there is nothing about installing it into a 4th gen, the wires on the tach are black white red and green and 2 little orange and black wires on the back, can anyone help me? </TD></TR></TABLE>
Well, i can assume red is power - black is ground.........green is probably a signal wire from somewhere. Did it not come with directions?
What model is it? - go to the website to see if they have a pdf or something.
Old Feb 19, 2006 | 11:47 AM
sohc prelude's Avatar
when i put my shift light in i only had 3 wires.. (ground, power, singnel ) i just ran the wires threw that thing that looks liek a speaker on the dash (it clips right in and out) down to the fuse box and pluged it ito liek the sunroof or something( anythign that always has power) and the ran the groudn wire to a screw on the side of the dash ( when the door is open )(theres 2) and then took the singnel wire to the idel sensor witch on my car was a few wires at a connecter right near the head andi jusy jamed it in there and hey it works.. but why dontsnt ur friend ask his firend how he had it hooked up.. like i said.. mine only had 3 wires .. hope that was some help?
Old Feb 19, 2006 | 11:48 AM
korney's Avatar
Default Re: installing tachometer w/shift lite (TheKINGPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">
What model is it? - go to the website to see if they have a pdf or something.</TD></TR></TABLE>
well its from autometer, and I have tried looking at the site, but nothing in spacific for a 4th gen lude. Is there any difference at all? between the cars? all I know is that its a for a four cylinder engine.
Old Feb 19, 2006 | 11:50 AM
well, i would assume that they have all the wires the same - seeing that all tachs are basically the same.
HAHAHA! I'm watching MTV, they have a little exercise thing for women thats supposed to raise their bust line. This **** is funny. Its a damn pole with a spring inside. Sorry - ah! And it costs $60.00. Wow....
Old Feb 19, 2006 | 11:53 AM
Default Re: (TheKINGPin)
yeah id say the same thing.. you just need to find were to plug it in on his prelude.. if its a f22 prelude i can go out and look and tell you exectly where mine is pluged in at.. if its h22 or h23 im not sure exectly where it would go.. but you can hook up the ground and power wire liek i said in my last post
Old Feb 19, 2006 | 11:55 AM
korney's Avatar
Default Re: (sohc prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc prelude &raquo;</TD></TR><TR><TD CLASS="quote">yeah id say the same thing.. you just need to find were to plug it in on his prelude.. if its a f22 prelude i can go out and look and tell you exectly where mine is pluged in at.. if its h22 or h23 im not sure exectly where it would go.. but you can hook up the ground and power wire liek i said in my last post</TD></TR></TABLE>
yeah it is a f22a1 (just like me!! )
Old Feb 19, 2006 | 11:57 AM
korney's Avatar
HAHAHA! I'm watching MTV, they have a little exercise thing for women thats supposed to raise their bust line. This **** is funny. Its a damn pole with a spring inside. Sorry - ah! And it costs $60.00. Wow....</TD></TR></TABLE>
haha...Where can you get it from?? ahah just kidding or am I? hmm.. haha that's some funny ****!
Old Feb 19, 2006 | 12:01 PM
Default Re: (korney)
ok. then its easy follow one of the wires form the distrubitor and it will go to the behind the head to the left.. there is to connectors.. its the one that u follwoed the wire to... punplug it.. the side in ur left hand is where u put the singnal wire in.. put the wire into the bottem right hole (as ur looking at it .. (your right)) and pulg it back in.. and there you go it should be working
Old Feb 19, 2006 | 12:10 PM
korney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc prelude &raquo;</TD></TR><TR><TD CLASS="quote">ok. then its easy follow one of the wires form the distrubitor and it will go to the behind the head to the left.. there is to connectors.. its the one that u follwoed the wire to... punplug it.. the side in ur left hand is where u put the singnal wire in.. put the wire into the bottem right hole (as ur looking at it .. (your right)) and pulg it back in.. and there you go it should be working</TD></TR></TABLE>
is this all in the area where the speaker thing is?
Old Feb 19, 2006 | 12:17 PM
korney's Avatar
i also have a white red black wires where do they go?
Old Feb 19, 2006 | 02:41 PM
korney's Avatar
ok well I have Connected everything, and I can't find where to get the wire (signal) through the fire wall. do I have to drill a hole? where is the area where I can lead the wire through and get it close to the speaker thing that pops out?
Old Feb 19, 2006 | 02:47 PM
korney's Avatar
bump
Old Feb 19, 2006 | 07:21 PM
prelude_h22vtec's Avatar
for a hole in the firewall, use the hole where the cruise control cable comes through. and you i suppose the speaker thing you're all talking about is the tweeter cover. take that off and you just thread the wires down through the small holes in there. i taped all the wires to a piece of a clothes hanger to get them through. oh and btw, i have my CC removed so i'm not sure if you'll be able to use that hole in the firewall easily.
Old Feb 20, 2006 | 05:10 AM
korney's Avatar
how did you get the wire throgh the fire wall???
Old Feb 20, 2006 | 05:11 AM
korney's Avatar
Old Feb 20, 2006 | 05:18 AM
Find a hole, or make your own - and then put a little rubber piece so the metal doesn't cut the wire.
Old Feb 20, 2006 | 07:09 AM
korney's Avatar
anyone else?
help please.
Old Feb 20, 2006 | 07:37 AM
mgags7's Avatar
there are plenty of holes you can run a wire through, just look from the engine side and use a hanger to get the wire through....
a simpler way to hook it up is to just splice into the tach wire down at the ecu.....
Old Feb 20, 2006 | 12:34 PM
Jos3ph's Avatar
I havn't installed one of those tachometers before but can't you connect the "signal wire" to the "tachometer wire" from the gauge cluster? The tachometer wire in a 4th gen prelude is a blue wire with silver spots and is located on one of the connectors that attaches to the gauge cluster.
Old Feb 20, 2006 | 02:28 PM
korney's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
a simpler way to hook it up is to just splice into the tach wire down at the ecu.....</TD></TR></TABLE>
hey how can I do this? can you tell me more details?
Old Feb 20, 2006 | 02:42 PM
korney's Avatar
help anyone?
Old Feb 20, 2006 | 02:58 PM
korney's Avatar
bump?
Old Feb 20, 2006 | 04:41 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Your tach wire is BLUE at the tach test connector on the pass strut tower in the engine compartment.
Old Feb 21, 2006 | 05:23 AM
korney's Avatar
Default Re: installing tachometer w/shift lite (ScareyH22A)
can I just splice the blue tach wire with the sliver spots in the gauge cluster to the green signal wire?
