Engine Code 3
Old Feb 14, 2006 | 05:16 PM
KoshTheKoala's Avatar
Default Engine Code 3
Engine code 3: Manifold Absolute Pressure Signal (high/low signal). What do I do about that? I spun out onto dirt/grass at about 60 mph... car stalled and when I started it up it gave me check engine light. I did about 200 miles so far with the light on and nothing bad has happened.
Here's another thing...
Ok so as I was checking the engine code, I noticed the ATTS light flashing. It was flashing slow and fast, like how the check engine light gives off MIL codes. After watching it for a while I got 72, 42, 72, 42 (yes, twice in a row), 41, 43, 32. Then it repeat. It went through that pattern 3 times before I gave up... is the ATTS light supposed to do that, or does it give off its own codes?
Old Feb 14, 2006 | 05:36 PM
brolli's Avatar
Default Re: Engine Code 3 (KoshTheKoala)
the map sensor code is just telling you that the signal is out of range, high or low. iether the sensor is faulty or the wiring to it is. i have no idea about the atts light.
Old Feb 14, 2006 | 07:04 PM
93h22a1vtec's Avatar
Default Re: Engine Code 3 (brolli)
kinda related... my abs light did the same thing when i was checkin for codes, i didnt count them out or anything, and this was on a obd1 4th gen
Old Feb 15, 2006 | 07:30 AM
Hm.. that's interesting. My car is stock btw.
Old Feb 15, 2006 | 09:27 AM
98TypeSH's Avatar
Default Re: (KoshTheKoala)
When you throw a CEL, it cuts the communication from the ECU to the ATTS Computer, thus throwing a ATTS light as well.
Fix the check engine light and the atts light will go out.
Old Feb 15, 2006 | 03:38 PM
H-seriesTech's Avatar
At this point if your ABS light is not staying on then i wouldn't worry about it but for the engine code I would reset the ECU and see if the code comes back on them you know there is a problem. To do this you can take out the ECU fuse or just remove the (-)Battery cable for about 2mins.
Old Feb 15, 2006 | 05:22 PM
Default Re: Engine Code 3 (H-seriesTech)
I'll lose all mly radio pre-sets won't I?
Old Feb 15, 2006 | 08:04 PM
If you pull the ecu fuse your radio will still have power
Old Feb 16, 2006 | 07:51 AM
98TypeSH's Avatar
you remove the clock/radio fuse from the engine bay fuse box, you will lose your station presets.
If you dissconnect the battery, you will lose your station presets. pick one
I suggest you replace the sensor with a known good or just replace the whole TB. If that doesnt fix your problem you have a short somewhere in the MAP wire.
Old Feb 17, 2006 | 09:17 AM
Default Re: Engine Code 3 (98TypeSH)
Where's the ECU fuse?
Oh well... no more engine light... spent like 10 min redoing my radio! x.x
caddoo ltd
Nov 18, 2013 04:22 PM
Jerkface38
Honda Civic (2001 - 2005)
Mar 28, 2013 04:52 PM
importdude2000
Jul 17, 2004 12:53 PM
