HELP HELP H22 swap problem
Old Feb 15, 2006 | 12:24 PM
92hatchs1's Avatar
Default HELP HELP H22 swap problem
someone please help me i got a 92 civic hatch wit a built h22 and it was spuddering and i took one of the spark plugs out and it was soked in gas then i turned over the car to try and get it outa the cylinder and it didnt stop coming outa the cylinder does anyone have any clue of what this might be thanks so much for all your help
Old Feb 15, 2006 | 12:33 PM
Lewdin' Incognito's Avatar
Default Re: HELP HELP H22 swap problem (92hatchs1)
er....taking the spark plug out and cranking it WILL pump more gas into it b/c your injector is still working
Old Feb 15, 2006 | 12:37 PM
jfish's Avatar
unplug that injector you need a noid light to test the signal it should blink. if its steady its your wiring or your ecu. if it blinks it maybe the injector is stuck. you can listen to the injector with a long screwdriver. put the blade on the injector and the handle to your ear it should click on and off.
Old Feb 15, 2006 | 04:35 PM
LudeyKrus's Avatar
Not only could it be a stuck injector, he could have bad wires/plug and that cylinder is not getting spark.
Put the spark plug into the spark wire, and touch the grounding wire to the head/valve cover while cranking. If it gets a nice, fat blue spark, your ignition is fine.
EG6 Love
Sep 24, 2013 09:11 AM
93Hammer
Dec 11, 2008 04:10 PM
96accordsir
Aug 6, 2008 06:07 AM
ek4__
Apr 12, 2007 04:42 PM
huge230
Oct 1, 2005 11:00 AM
