DP Nitrous...
Old Feb 21, 2006 | 04:57 PM
scootertribe's Avatar
Default DP Nitrous...
I have a '99 Prelude w/ basic bolt-ons. I'd like to set up a DP nitrous system, and I was wondering what Intake Manifold I should use.
I would like to buy a new one for 2 reasons: 1. to install the nozzles w/ the manifold off (minimizing downtime), and 2. To gain a few horsed N/A and while on the juice. Any experience and advice would be great, thanks in advance.
Old Feb 22, 2006 | 06:24 AM
Default Re: DP Nitrous... (scootertribe)
Hmm...Someone has got to know.
Old Feb 22, 2006 | 06:56 AM
98vtec's Avatar
moderator emeritus
euro R
Old Feb 22, 2006 | 08:56 PM
Default Re: DP Nitrous... (98vtec)
thanks for the reply.
Old Feb 23, 2006 | 09:50 AM
NXLude's Avatar
Any one you want....you can install the DP in less than 6 hours, even if its your first time. Id install the whole kit, then do the tapping and such, then your cars not really down. It will be down just as long in you do the euro r.
Old Feb 23, 2006 | 10:14 AM
Default Re: (NXLude)
Ok, so the manifold is preference--speaking of which, i think id rather have one that has all of the oem fittings, etc.
But to install the DP, is it just a matter of drilling and tapping? (besides the rest of the kit)
Old Feb 23, 2006 | 01:45 PM
NXLude's Avatar
Yes, you just tap your nozzle holes, put the nozzles in, and use a tube bender to bend the hardlines to the distribution block....not too hard. You can also have SS lines made up if you dont want to mess with hardlines. The hardware side of the install is easy, the wiring takes longer to do, and that isnt very hard at all.
Old Feb 24, 2006 | 02:07 PM
I pretty much suck at wiring, so would you recomend a shop to do that part for me? Or are most instructions pretty well written?
Old Feb 24, 2006 | 06:06 PM
NXLude's Avatar
its not that hard....2 power, 2 ground, 1 wot switch and 1 hand switch.....
Old Feb 25, 2006 | 11:03 AM
Im looking around online, and it seems it may be difficult to find a Direct Port kit that will jet down to 35 or 50 hp. Any recomendations?
Old Feb 25, 2006 | 12:50 PM
NXLude's Avatar
Default Re: (scootertribe)
run a 75......its not too much with a dp....the NOS DP will jet to 55
vtecftw
Apr 15, 2007 05:45 PM
HondaGuRu
Jul 29, 2003 12:02 PM
DSGB.
Dec 22, 2001 01:12 PM
redteg1
Dec 18, 2001 11:43 AM
