dizzy problem
Old Aug 7, 2013 | 05:44 PM
p1mmiz321's Avatar
Default dizzy problem
Hi there folks,,
i have been busy installing a f20b in my prelude...
long story short .
i was going to fire it up but nothing just some back fire or miss fire..
here what i did...
swapped a new oil pump and swapped over the crank sensor and crank pulley for the timing belt and i have left the gear for the balance shaft since the crank sensor is using it for timing ...
i have use the jdm f20b dizzy but i have only connected the 4 wire to it... power the black and yellow wire , also the yellow /green ECM and i have connected the blue wire together and the black for ground. i have left the other not connected.
my question is if i was going to use the crank sensor to the oil pump do i need to use the old original external dizzy ??? do the jdm one need to have the crank sensor wire connected any way to work properly ?
Old Aug 8, 2013 | 03:08 AM
Acidcrakker's Avatar
Default Re: dizzy problem
What obd is your engine and what obd is your car.
Old Aug 8, 2013 | 07:17 AM
p1mmiz321's Avatar
Obd2a
hbyrd8701
Jan 18, 2009 12:56 PM
Naturally Aspirated
11
Jul 27, 2004 10:09 PM
AVATAR
Jul 10, 2004 08:42 AM
