H22 question please answer
Old Jul 21, 2013 | 06:52 AM
Ryanh22aprelude's Avatar
Icon2 H22 question please answer
Okay so im building a h22 head getting some very high lift cams, (highest lift and duration you can get for a N/A street car) and polishing intake ports, 3 angle valve job and shaving head down a little. My question is this: Is it worth the money to get an aftermarket intake manifold or am I better off with a stock one?? I have to buy one anyway because I don't have an h22 one so am I better off just getting a stock one or will it make noticeable gains with the racing one preferably skunk 2. Ive actually heard of people LOSING horsepower with them but I mean I would think it would help seeing as the cams I got. So is it worth it? or will it make my car sluggish? I would want it to add at least like 5 horsepower if Im going to get one.
Old Jul 21, 2013 | 06:57 AM
honda_12V's Avatar
Default Re: H22 question please answer
If you are going all out with head work, the skunk wont be able to do justice in my opinion.
I would get a euro r manifold instead of the skunk.
But if you are going all out, as in like u asked - best N/A cams are Skunk Pro 3 - you would need the springs and retainers to go with that, then u definitely want a race h22 manifold. A good manifold, along with a complete setup could give you great gains. Do it wrong even if one component does not match the other, u could restrict what you achieve.
My 2 cents.
Regards
Old Jul 21, 2013 | 04:44 PM
snobordboy's Avatar
Moderator
Check out some thread on H22 manifold testing by NAH2B, pretty much found that gutting out a stock manifold PROPERLY will give the best gains compared to euro-r or skunk2.
There are other big sheet metal manifolds out there like Golden Eagle, but those are really meant for turbo cars, and generally lack torque on an n/a car.
Hopefully you are upping the compression in the bottom end, or those huge cams aren't going to do you much good.
Old Jul 21, 2013 | 06:42 PM
preludeNApower's Avatar
X2 on that one
And check your p2v clearance real well
Old Jul 21, 2013 | 08:33 PM
Sparksman's Avatar
He's running stock internals on a H23A1, I suggested skunk Pro 1's for you already in another thread because your on stock bottom end. Any bigger and you will lose power unless you have way higher compression.
Ive heard that the stock modified are the best as well. But that also take shop time to gut all the runners equally, or in the hands of someone experienced that knows what they are doing.
Old Jul 22, 2013 | 05:47 AM
Are h22a1 and/or h22a4 cams compatible with a jdm h22a??
Old Jul 22, 2013 | 06:36 AM
snobordboy's Avatar
Moderator
For stock cams the H22A jdm cams will be the best, unless you can track down some type-s cams. But all of the Honda H22 cams will work in any head, although some people have had clearance issues with the type-s cams in certain heads.
If you really want to change cams, I agree with the Skunk2 PRO1 cams, I run them in my H23Vtec, and think they are great for daily use and high rpm/ track use. You do need to do springs and retainers along with them, and check your v2v and p2v very well, and have adjustable cam gears and degree the cams properly on the engine.
Old Jul 22, 2013 | 07:25 AM
Honestly is it going to be worth it for me to get some skunk2 pro 1 cams though or just keep the stock jdm h22a ones?? i wanna make power with stock block and just headwork
Old Jul 22, 2013 | 12:18 PM
1funryd's Avatar
Cams always help, but you must tune for them, so you dont want to just install cams and not tune.
Old Jul 22, 2013 | 02:44 PM
Right but im just asking if its gonna be worth it if its that much of a difference over stock h22a
Old Jul 22, 2013 | 03:20 PM
Im shaving the head to up compression over stock
Jianshatch
Jan 7, 2017 09:41 PM
DA is best
Jan 2, 2012 03:24 PM
michaelprice83
Feb 2, 2009 04:45 AM
rollercosta123
Feb 5, 2007 06:21 PM
