Power window problem
Old Jun 7, 2015 | 03:52 PM
ERICBREEZY97K's Avatar
Default Power window problem
so I have had this power window problem for about 3 weeks now and I still do not know what the problem is. I used the manual and I checked the fuses which are ok, and so is the relay. I bought a new master switch and still nothing. BOTH of my windows stopped working randomly. the manual then says to check the control unit input? where is that located and what does it do? I read a couple of forums and some people had the same problem and usually it was the multiplex unit? my power locks also started acting weird. my power mirrors still work .when I hit the power lock to close both doors with the switch only the passenger door locks. before when I would both would lock. not only that but when I would manually lock it from the drivers both would and now it doesn't. what is the problem, help me !!!
Old Jun 8, 2015 | 02:19 AM
thirsk66's Avatar
Default Re: Power window problem
Do you have an alarm system on your car? Also the multiplex units since there are 3 of them one of them is on your passenger's side kick panel, one in your driver's side door and one by the driver's side kick panel. Im assuming that if you needed to replace one of them that one in your driver door would be first.
Old Jun 8, 2015 | 04:26 AM
no alarm system
Old Jun 8, 2015 | 06:45 PM
backinblue92's Avatar
I think he's right about the multiplex in the driver door. Cuz that's the side that controls both windows. The pass side multiplex only controls that side, so I'd rule it out.
The one in the kick panel is a possibility but I remember it not being a control switch but a relay
Old Jun 9, 2015 | 04:45 AM
could the drivers door multiplex really be the culprit ?
Old Jun 10, 2015 | 06:21 AM
snobordboy's Avatar
Moderator
Yup, they can cause all sorts of issues. Best way to replace it is go find one on a car of the same year in a junkyard, not a common part to fail so it should be there.
Old Jun 10, 2015 | 08:50 PM
rj27's Avatar
maybe its as simple as a battery problem. just maybe..lol
Old Jun 11, 2015 | 11:54 PM
If it was a battery problem, he'd have some more significant other symptoms.
Ethanc
Apr 12, 2011 06:15 AM
tormont
Dec 1, 2010 08:44 PM
SmoothLude
Jul 11, 2009 06:28 PM
theeogflip
Aug 13, 2007 07:36 AM
jArceo
Jun 22, 2004 07:59 PM
