Help
Old Jul 12, 2015 | 04:29 PM
glpalmer's Avatar
Default Help
My 1993 honda prelude starts up fine and runs good but sometimes it shuts off on its own or when I turn it off it does not start back up in till it sits for a while
Old Jul 12, 2015 | 05:23 PM
thirsk66's Avatar
Default Re: Help
It sounds like your ICM in your distributor is bad or your main relay or your ignition switch at your key is bad. Just have to do some troubleshooting to track down which one it is causing your issue.
Old Jul 12, 2015 | 07:26 PM
holmesnmanny's Avatar
Default Re: Help
When it doesnt start, immediately check for spark and fuel.
Old Jul 12, 2015 | 09:27 PM
backinblue92's Avatar
Default Re: Help
Well there's not much detail here. But main relay is a trouble spot for preludes
Old Jul 13, 2015 | 06:50 AM
snobordboy's Avatar
Moderator
Default Re: Help
The no styart symptom sounds like Main Relay to me, but the shutting off, not so sure. Could be dist. related, or ignition related, or fuel pump shutting off from main relay as wel, many possibilities.
The first thing I would do is swap in a good main relay.
Blazinmiller
Mar 12, 2024 10:32 PM
robs accord
Aug 10, 2013 11:55 PM
shreddinryguy
Jun 26, 2005 02:03 PM
speedymon
Dec 13, 2004 11:18 PM
1stealthls
Jul 30, 2002 06:36 PM
