Found: Shock Knock
Old Jul 13, 2003 | 02:37 PM
Cottonwoodz's Avatar
Default Found: Shock Knock
Well, my knocking sound from the rear end has been found.. The sound has gotten progressively worse in the last year. It turns out to be, the rear swaybar stabilizer links.The arm that holds the swaybar onto the rear spindles(knuckles) are shot. So every little bump in the road it bangs against itself, makeing a knocking sound. Both of them need to be replaced at 42 bux apeice. So If anyone that has a knocking noise comeing from the rear wheelwell area, I would check the links on the swaybar. You shouldnt beable to move them up and down.
Old Jul 13, 2003 | 03:49 PM
rjr162's Avatar
Default Re: Found: Shock Knock (Cottonwoodz)
hey... $42 a peice... Most rear 25mm strutbars run like that... $240 each? Give or take. That's $324. Damn so the neuspeed would still be $100 over that lol.
Might as well spurge!
Old Jul 13, 2003 | 04:23 PM
fe519's Avatar
Default Re: Found: Shock Knock (rjr162)
hey cottonwoods... what year prelude you got? and how can you check if its shot or not cause I got that sound too
Old Jul 13, 2003 | 06:57 PM
user 9782082308's Avatar
Default Re: Found: Shock Knock (fe519)
Nice find
Hopfully now I won't have to pull the rear suspension yet again.
Old Jul 13, 2003 | 09:18 PM
IA93Vteclude's Avatar
Default Re: Found: Shock Knock (racerx)
Have you guys already tried that replacement collar for the rear shocks? Its a honda TSB bulletin.
Old Jul 14, 2003 | 10:49 AM
GSRpower's Avatar
Default Re: Found: Shock Knock (IA93Vteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IA93Vteclude &raquo;</TD></TR><TR><TD CLASS="quote">Have you guys already tried that replacement collar for the rear shocks? Its a honda TSB bulletin.</TD></TR></TABLE>
I would like to try this first...do you know a part number?
Old Jul 14, 2003 | 12:38 PM
Default Re: Found: Shock Knock (GSRpower)
Yes I do, I had honda send my the the actual bulletin. But I am not home right now, I will put it up later today or tomorrow.
Old Jul 14, 2003 | 06:43 PM
Shocks are new with, bushings, collar, ext... Did it before and is still doing it. This might not be everyones problem, but in my case it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> and how can you check if its shot or not cause I got that sound too</TD></TR></TABLE>
All you have to do to check it is, grab the rear swaybar were it connects to the spindle, push and pull up and down, and see if it moves and makes a knocking sound.
Old Nov 25, 2005 | 05:27 PM
M@'s Avatar
M@
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">Well, my knocking sound from the rear end has been found.. The sound has gotten progressively worse in the last year. It turns out to be, the rear swaybar stabilizer links.The arm that holds the swaybar onto the rear spindles(knuckles) are shot. So every little bump in the road it bangs against itself, makeing a knocking sound. Both of them need to be replaced at 42 bux apeice. So If anyone that has a knocking noise comeing from the rear wheelwell area, I would check the links on the swaybar. You shouldnt beable to move them up and down.</TD></TR></TABLE>
I had the same problem. Lucky for me the rattle was in the rubber bushings and not the knuckles. So the cost was $5.
matt
Old Nov 26, 2005 | 10:29 AM
E-Money's Avatar
Great find man, I've been having that same sound for about a year or so now. I was just about make the move onto the new struts.
Old Nov 26, 2005 | 12:04 PM
M@'s Avatar
M@
Default Re: Found: Shock Knock (E-Money)
I did the struts and the noise was still there. So I did alittle searching to find that post. Its alot cheaper if this is problem.
Old Feb 26, 2006 | 01:50 AM
Default Re: Found: Shock Knock (M@)
Shock knock cure
Old May 19, 2007 | 12:31 AM
w00t
Old May 19, 2007 | 01:12 AM
zirac50's Avatar
i have some noise too but not knock. I've been looking for it, it sounds like a squicky noise like a door hinge noise. when I hit a bump, I ca hear it but not too loud. what could that be? any idea?
Old May 19, 2007 | 01:42 AM
Flip.'s Avatar
Default Re: Found: Shock Knock (zirac50)
Thanks
Gonna check 2 see if this is the same problem I have tomorrow.
Old May 19, 2007 | 04:26 AM
mgags7's Avatar
so you wait three months after the last post and post this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">Shock knock cure </TD></TR></TABLE>
nice pat on your own back
then you go a year and three months and this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">w00t</TD></TR></TABLE>
wtf is wrong with you, you have the maturity level of a high school kid.
Modified by mgags7 at 10:44 PM 5/19/2007
siblue_gzer
Honda Civic (2006 - 2015)
May 29, 2007 04:48 PM
Shushiplease
Mar 9, 2007 01:47 PM
chadmasterc
Suspension & Brakes
Jan 18, 2007 07:03 PM
SHG_EasyE
Oct 18, 2005 03:20 AM
jwa4378
Honda S2000
May 29, 2005 12:35 PM
