lowering compression...
Old Jul 9, 2003 | 05:43 PM
Arch-Angel's Avatar
Default lowering compression...
I know that probably the best way to lower the CR is to invest in some lower compression pistons, but that costs mega $$$!
So what about the alternatives?
Is using a lower compression metal head gasket a *SAFE* way to do it? or is it simply best to save up and go with the pistons?
Old Jul 9, 2003 | 10:03 PM
TraKtioN's Avatar
Default Re: lowering compression... (Arch-Angel)
decrease power? even for a turbo application theres no point.
Old Jul 9, 2003 | 11:26 PM
DubbleD's Avatar
Default Re: lowering compression... (TraKtioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">decrease power? even for a turbo application theres no point.</TD></TR></TABLE>
someones gonna bust out the hammer on you for this one...................
Old Jul 9, 2003 | 11:51 PM
Arch-Angel's Avatar
Default Re: lowering compression... (DubbleD)
yeah and I could just run 20psi on stock internals too!!!
It isn't about the most power... boosting is obviously going to give me extra HP in abundance, but I would mind driving it more than once too!
Old Jul 10, 2003 | 06:05 AM
MugenPoweredLude's Avatar
the gasket is ok.....but your engine might not last long.....best bet would be to build the motor to save you headaches and frustration
Old Jul 10, 2003 | 07:21 AM
Paluce's Avatar
It almost hurt reading this!
Old Jul 10, 2003 | 07:27 AM
Boostless97Lude
Guest
Posts: n/a
starts twitching.......
should i get him for this guys, or just leave it alone???
Old Jul 10, 2003 | 07:53 AM
rjr162's Avatar
There *IS* a point. Sure you can keep the compression at 10:1 and run lower boost and still end up with teh same results... BUT there is a major flaw in this thinking... well not a flaw but a big *** headache.
Think about it... if you're running 8.5:1 and trying to tune it... a 1 psi change in boost isn't going to affect the overall air pressure in the cylinder as 10:1 with a 1 psi change would.
With 10:1, a small change in pressure will make a bigger difference in A/F tuning etc. When you're at 8.5:1 it gives you more room for tuning and less chance of blowing **** up.
The only advantage to using 10:1 rather than 8.5:1 is with the 10:1 you'll reduce some of the lag before the turbo kicks in since your compression under vaccuum is higher.
Old Jul 10, 2003 | 08:43 AM
TraKtioN's Avatar
Default Re: lowering compression... (rjr162)
Newbs...get a hondata and stfu.
Old Jul 10, 2003 | 08:46 AM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">Newbs...get a hondata and stfu.</TD></TR></TABLE>and blow your ******* motor
improper tuning at high compression WILL blow something, and with high compression you have very little room for error
stock pistons can't hold the pressure
and if you run high boost on high compression you must run 110+ octane or alcohol
shall i keep going?
Old Jul 10, 2003 | 09:33 AM
Shakes's Avatar
space cadet
Default Re: lowering compression... (UN-Boosted97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UN-Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">and blow your ******* motor
shall i keep going?</TD></TR></TABLE>
shut up sam and just give him the
Old Jul 10, 2003 | 09:51 AM
TraKtioN's Avatar
Default Re: lowering compression... (shakes)
My point is dont change your pistons if they're alllredy high, just use less boost. Sure it may be harder to tune but you'll have better low end. 7+3=10 or 3+7=10 same thing!
Old Jul 10, 2003 | 09:54 AM
Boostless97Lude
Guest
Posts: n/a
or get a headgasket and drop the compression
Old Jul 10, 2003 | 01:07 PM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">My point is dont change your pistons if they're alllredy high, just use less boost. Sure it may be harder to tune but you'll have better low end. 7+3=10 or 3+7=10 same thing!</TD></TR></TABLE>
Not quite that simple.... the tuning level becomes much harder.
Old Jul 10, 2003 | 01:37 PM
2kflamedlude's Avatar
Old Jul 10, 2003 | 01:42 PM
DubbleD's Avatar
Default Re: lowering compression... (2kflamedlude)
lol damn u got hella hammer...ssssucka
Old Jul 10, 2003 | 05:44 PM
Arch-Angel's Avatar
ok ok, as amusing as this all is...
the reason I asked is because I am looking at a turbo kit that comes with a Rideal (?) headgasket that is meant to lower compression, and I want to know if that will be enough to protect my engine as a daily driver.
The plan is to run about 8psi with a T3/4.
if this spells trouble, what should I get to build up the engine?
BTW, did you mean 3:1 + 7psi = '10' is the same as 7:1 + 3psi = '10'????
if so, you really need to learn more about cars AND maths before you start shooting you mouth off...
Old Jul 10, 2003 | 07:03 PM
TraKtioN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arch-Angel &raquo;</TD></TR><TR><TD CLASS="quote">ok ok, as amusing as this all is...
if so, you really need to learn more about cars AND maths before you start shooting you mouth off... </TD></TR></TABLE>
Like I said newbs, ya 3:1 + 7psi = 10 haha
Old Jul 10, 2003 | 08:30 PM
LordVtec's Avatar
has an inline pro low compression head gasket for sale.. (still)... OF TOPIC: WASSAH SAM!? i decided to peek my head back in here to see whats up..
Old Jul 11, 2003 | 12:56 AM
Arch-Angel's Avatar
Default Re: lowering compression... (LordVtec)
what compression on the inline gasket?
b00stedOne
Jul 28, 2014 09:56 AM
ITR_1211
Jan 18, 2004 08:09 AM
BOOSTEDcivicB18C1
Sep 10, 2003 08:37 PM
FyReo3
Jun 5, 2003 11:18 PM
madman604
Jun 2, 2003 11:09 AM
