power locks
Old Aug 6, 2003 | 07:41 PM
puffxy's Avatar
Default power locks
i was putting my stock intake box back on just to see the difference today.. i have no idea if this is related but it seemed to happen right afterwards. My power doors don't work. Not the switch from the interior, nor the alarm. Is there a wire near the intake area that i could have snapped? any ideas? i checked the fuse, replaced it, nothing..
Old Aug 6, 2003 | 09:02 PM
SuperSH's Avatar
Check all of the fuses, they are interrelated.
Old Aug 7, 2003 | 01:35 AM
Elkins911's Avatar
Default Re: (SuperSH)
check the connection at the actuall battery. my door locks are connected to my alarm. if power is disconected to the alarm, neither the alarm nor the door locks will work. good luck.
Old Aug 7, 2003 | 04:48 AM
Sephro's Avatar
Default Re: (Elkins911)
yeah check at the battery because sometimes when alarms are installed the Power locks are run off the alarms power rather than the cars (hope that makes sense).
Sometimes when they install alarms they will run another wire to the battery, much like you would if you installed an amp.
So I would check to see if that is the case and if you bumped it and it's not connected.
So basicly same thing as ^
Old Aug 7, 2003 | 11:06 AM
caliriptide's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSH &raquo;</TD></TR><TR><TD CLASS="quote">Check all of the fuses, they are interrelated. </TD></TR></TABLE>
Ya dude&gt; Make sure you check them real good&gt; I kept haven my fuse blow for my break lights&gt; And the damn horn is on the same circut! Turns out the owner befor me left (2) wire just hanging, from the break light (wing)&gt; Dude shaved the stock wing&gt;along with everything else. Sorry&gt; Was kind off your subject&gt;? Somehow related though
Old Aug 7, 2003 | 02:20 PM
puffxy's Avatar
i checked *every* fuse.. they all seemed fine.. and i replaced some that looked a little dirty or black.. tested it, nothing. Closed the hood and said screw it. tested it one more time just to be sure, nothing. Later i had to go out, hit the alarm and it unlocked o.O uh.. tried power locks inside, they work.. wth?? oh well :X
mfreeman
Audio / Security / Video
Sep 30, 2014 01:00 PM
mish__
Sep 4, 2013 11:23 AM
oresama
Sep 6, 2011 09:47 AM
doubleoazn03
Oct 17, 2008 06:07 PM
o_Rage_o
Jul 22, 2002 05:11 AM
