H23 Compression Test numbers
Old Aug 10, 2003 | 12:20 PM
lewd43's Avatar
Default H23 Compression Test numbers
I'm going over to my friend's house to run a compression test on my motor to see how things are looking, but im wondering what the range im supposed to be looking for is. I've seen posts that h22's are getting 205-215 across all 4 cylinders, but i know mine are supposed to be lower cause of the compression ratio. any idea what numbers im searching for. its a stock block and head
Old Aug 10, 2003 | 12:26 PM
RHD_BB4T's Avatar
Default Re: H23 Compression Test numbers (lewd43)
Max psi: 178
Min psi: 135
Max variance: 25psi
HTH!
Dan P.
Old Aug 10, 2003 | 06:34 PM
del_parker's Avatar
Default Re: H23 Compression Test numbers (Dan_P)
isn't 160 supposed to be expected number? or is it different?
Old Aug 10, 2003 | 09:39 PM
JBG's Ferio's Avatar
Default Re: H23 Compression Test numbers (del_parker)
I ran a compression test on my car last week, and the results were 155 all the way across. Maybe that could be of some help.
Old Aug 11, 2003 | 04:20 AM
lewd43's Avatar
thanx for the much needed info i'll post back with the results, the weather held us back on the test. i hate florida weather
Dark_Teg
Oct 15, 2009 07:56 PM
Jos3ph
Jan 14, 2008 09:45 AM
2old_honda
Apr 12, 2002 01:25 AM
