oil light problem
Old Aug 5, 2003 | 10:20 PM
monalisa overdrive's Avatar
Default oil light problem
yeah, my oil light starts flashing if i have to hit the brakes hard or if i take a Really tight turn...any explanation for this? just fyi my front engine seal is leaking oil and i figure that must have something to do with it... and the valve covers are leaking oil as well. any clues would be much appreciated, thanks
Old Aug 5, 2003 | 10:24 PM
str8rcn's Avatar
Default Re: oil light problem (monalisa overdrive)
Check the level of the oil.
Modified by str8rcn at 11:36 PM 8/5/2003
Old Aug 5, 2003 | 10:26 PM
Default Re: oil light problem (str8rcn)
how would that affect the oil light?
edit: just got a brake job yesterday, i dont think that could be it
Old Aug 5, 2003 | 10:32 PM
str8rcn's Avatar
Sorry i cant read. Meant check the oil level.I knew i couldnt do 2 things at one time without screwing one of them up.
Old Aug 5, 2003 | 10:38 PM
JBG's Ferio's Avatar
That's not a good sign. My car did that once, and I had about a quart of oil in my car. so..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8rcn &raquo;</TD></TR><TR><TD CLASS="quote">Check the level of your oil.</TD></TR></TABLE>
Old Aug 5, 2003 | 10:42 PM
Fly1865's Avatar
the oil pump is mechanical, and the oil pressure sending unit doesn't sense the amount of oil pressure in your motor. Check your oil level frist off. Add if needed. If the problem is still there check your sending unit with an oil pressure gauge. The unit is located right below the oil filter. Just unscrew the sending unit and screw in the pressure gauge and crank the car over a few time( remove the distributor wire from the coil). check the oil pressure with your Helm's manual and see if it is in spec.
Old Aug 6, 2003 | 04:43 AM
Sephro's Avatar
Default Re: oil light problem (Fly1865)
I would say oil level is low. I had this happen when my oil pan seal was bad. The oil is displaced when the car is either stopping hard or cornering hard thus making it think that there is none in there. Yes there is some in there but not enough. I wouldn't drive it until the oil is filled back up.
Old Aug 6, 2003 | 05:01 AM
Prelude Vtec 23's Avatar
Default Re: oil light problem (Sephro)
If you check your oil level and it is fine, then most likely your oil pump is going bad.
Old Aug 6, 2003 | 01:40 PM
Default Re: oil light problem (Prelude Vtec 23)
just got my oil changed and it hasnt come back on so far....hope it stays that way
itzyaboyzeem03
Jul 1, 2016 04:40 PM
soon2bdropped
Dec 10, 2006 01:20 PM
motormike40
Aug 21, 2006 06:02 PM
DC_RaceR
Feb 23, 2006 02:00 PM
Foxcow
10
Dec 16, 2004 08:56 PM
