rubbing
Old Aug 10, 2003 | 12:26 AM
501 Lude's Avatar
Default rubbing
I just got some 225/40/18 tires and now i'm rubbing. I was wondering if anybody has run into this and what they did to solve it.
Old Aug 10, 2003 | 01:55 AM
preluda92's Avatar
Default Re: rubbing (501 Lude)
ummmm, what kind of springs do you have? I have Skunk2 coilovers and the same sized tire. Just lowered them until they rubbed then I put them up a little more.
Old Aug 10, 2003 | 07:52 AM
MugenPoweredLude's Avatar
you got the wrong tire size and more than likely im assuming you have a 42+ offset???
and im also guessing you rub in the rear...in that case shave the rear tabs....
heres how to find them...
where the rear bumper meets the rear quarter panel.....there should be something sticking out on the inside of the fender....those are what you shave
Old Aug 10, 2003 | 11:45 AM
501 Lude's Avatar
Default Re: (MugenPoweredLude)
I also rub in the front too when i take a sharp turn. What tire size should i run with 18's with 40 profile. I have stock suspension, will getting kyb agx shocks and putting them on the stiffest setting help? thanks
Old Aug 10, 2003 | 07:05 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (LudeReasons)
roll the fenders. research for more info.
Old Aug 11, 2003 | 09:50 AM
silver97prelude's Avatar
I have 225/40/18 Kuhmo's and mine used to rub.
I had to shave a small piece of the back bumper that was sticking into the wheel well on both sides. I just used a dremmel and now it barely rubs on large bumps. I still have stock suspension, but I have a speaker box in my trunk. Hope this helps.
showtymers619
Honda S2000
Feb 17, 2008 08:29 PM
b18ef8
Honda S2000
Sep 8, 2005 09:35 PM
Jason84
Aug 9, 2004 10:35 AM
badasssi
Oct 9, 2003 09:05 PM
Shingoblade-GSR
Apr 11, 2003 10:24 PM
