Insulate the Intake?
Old Aug 7, 2003 | 10:16 AM
Jagan'92's Avatar
Default Insulate the Intake?
I know I'll lose the shiny chromeness, but since the intake gets so hot, wouldn't it make sense to use insulation and wrap the thing? I'm thinking to use that heat wrap that goes around headers and wrap up the intake inside the engine bay. What do you think? Even if cold air is coming in the filter, going through that hot tube can't be good.... or does it matter?
Old Aug 7, 2003 | 10:26 AM
NathanMorris's Avatar
Default Re: Insulate the Intake? (Jagan'92)
You want the stuff they wrap AC ducts with from home depot...it keeps hot air out, and cold air in....the header wrap does the opposite. It works very nicely from all reports I have heard, and I've been meaning to do it myself - but alas, other priorities right now. Anyhow, do it is what I say....it seems to be all the rage in the JDM scene.
Old Aug 7, 2003 | 10:44 AM
577HondaPrelude's Avatar
Default Re: Insulate the Intake? (92Lx)
it's not a bad idea at all, in fact I have it on my intake. Not header tape but heat reflective tape.
Old Aug 7, 2003 | 10:54 AM
Jagan'92's Avatar
is this AC tape the same as the heat reflective tape mentioned above? I do remember seeing that the header tape kept heat inside the header, I thought it was the same thing to keep heat in as keep cold in. oh well. ok good, should be able to pick up some insulation at home depot.
One thing though, would be that making sure the AC insulation is made for high heat areas. How hot would the engine bay get normally? Would it be better to go with some JCwhitney type heat reflective tape?
Modified by Jagan'92 at 8:22 AM 8/8/2003
Old Aug 7, 2003 | 02:30 PM
pentaq's Avatar
I have my short intake insulated with stuff for pipes. It helps to avoid heating all the intake pipe. And makes my intake a little bit more quiet.
pentaq
Old Aug 7, 2003 | 07:03 PM
user 9782082308's Avatar
Default Re: Insulate the Intake? (pentaq)
This is debatable, but for every 11 degrees you lower intake temp you gain roughly 1hp.
7rrivera7
13
Oct 25, 2007 11:12 AM
kornerk12
May 2, 2007 05:34 PM
adiDAs
Feb 23, 2006 04:05 PM
dgarcia
Jul 15, 2005 05:10 AM
slvrcivic97
Nov 16, 2002 04:08 PM
