Question: VTEC's
Old Jan 24, 2011 | 09:25 PM
hslater's Avatar
Default Question: VTEC's
Hi i just purchased a 1998 Honda Prelude Base Model. The engine specs are 2.2 engine with DOHC VTEC (automatic).
My question is how do you drive an automatic VTEC engine? Do you just drive it normally and the VTEC engages itself? Or do you need to floor the gas to get the maximium VTEC engagement on the engine.
And if your rpm is not high enough..does that mean the VTEC doesn't engage?
THANKS ahead of TIME if you have an ANSWER for me..
Old Jan 25, 2011 | 04:56 AM
godslayer's Avatar
Default Re: Question: VTEC's
http://www.lmgtfy.com/?q=VTEC&l=1
VTEC is NOT nitrous.
VTEC is NOT turbo/super charging.
VTEC is NOT VTECH.
Old Jan 25, 2011 | 05:19 AM
Rude Awakening's Avatar
Daughter not possible
^ I know you're trying to be cute, but he didn't mis-spell VTEC.
Old Jan 25, 2011 | 06:28 AM
nus_dogg's Avatar
Lol.
VTEC engages at 5.2K RPM for stock engagement. There's certain criteria that must be met in order for VTEC to work:
-Oil Pressure has to be in spec.
-Engine has to be normal operating temp.
-And you have to reach certain RPM(5.2K on factory H22s) depending if it's stock or set to from the tuner who dyno & tunes your vehicle.
Old Jan 25, 2011 | 07:43 AM
hslater's Avatar
VTEC is NOT VTECH.
Thanks a lot that helps. So i will just drive it normally and the VTEC will engage itself?
Old Jan 25, 2011 | 02:15 PM
crxsleeper210's Avatar
Yes it engages by "itself"....Unless you have it hooked up to a swith to "manually" engage it lol
Old Jan 25, 2011 | 04:01 PM
Eclectia's Avatar
^ Do people actually do that?
Old Jan 25, 2011 | 04:51 PM
rchid's Avatar
^^^^ I'm going to assume you aren't asking a serious question lol
Old Jan 25, 2011 | 06:15 PM
Kronn 98SH's Avatar
It will continue to engage by itself until the transmission dies, which will be soon. And your Nikes don't have VTEC, so it will suck.
Old Jan 25, 2011 | 08:32 PM
hslater's Avatar
I have seen these trans go to 300,000 miles. I hope mine does
Old Jan 26, 2011 | 07:40 AM
serjey15's Avatar
Yeah dude these 5th gen prelude auto trannys go out fast. Cuz they have that tip tronic gay ****, and it isnt really developed cuz its 1997 lol. one of the first tip tronic trannys, so thats why they go out before the first oil change.
Old Jan 28, 2011 | 10:19 AM
hslater's Avatar
Huh? What is tip tronic trannys?
Old Jan 28, 2011 | 10:22 AM
hslater's Avatar
Default VTEC VS SI (Sport Injected)
Yo i'm new here and this might sound like a dumb question but...
what's faster a 2001 Honda Prelude Base 2.2 VTEC or a 2001 Honda Civic SI
and what's better SI or VTEC?
thanks bro
Old Jan 28, 2011 | 01:08 PM
Green Crack's Avatar
Default Re: VTEC VS SI (Sport Injected)
thanks bro
Ummm dude there's no 2001 Honda Civic Si.
Old Jan 28, 2011 | 01:51 PM
easy's Avatar
V-tec refers to a system that is part of your motor. It changes how your valves lift and close to allow more air/gas mixture into the motor on the intake stroke and more exhaust gasses out on the expulsion stroke, and the system is set to change that because these settings are more or less efficiant in different rpm ranges. So, using a system like that allows you to use some settings in the lower rpm range that are not as optimal for the higher rpm and the same for the higer rpm range.
Si refers to a model of civic. So, a Si civic could have a motor that includes a V-tec system (all si's do in some form) but a civic dx or ex might not.
Old Jan 28, 2011 | 07:54 PM
nus_dogg's Avatar
An H22A4 will dust an EP3 Si(160bhp K20A3) IMO cause those EP3 are slow as hell and the shifter on those are higher up on the center consol which is a weird design from Honda.
Old Jan 28, 2011 | 09:19 PM
hslater's Avatar
Well considering that the 2001 Honda Prelude is a 2.2 engine VTEC, i would assume it's faster than any Honda Civic Si's ever made.
I think the si is only 1.8 engine?
Old Jan 28, 2011 | 10:22 PM
NOFX's Avatar
H-T White Ops
VTEC just engages once the car reaches a certain RPM, is up to temp and going at least a certain forward speed or faster iirc. For example, you can't hit VTEC in reverse.
thanks bro
Now, I had to look up some of the following because I wasn't sure of the times or the Prelude specs. Anyway, this is what I found out:
The 5th gen Prelude Base model with an automatic transmission came with the H22A4, a 2.2L DOHC VTEC engine with 197hp and 156lb-ft. 0-60mph in 8.5 seconds. I don't know about the automatic, but the manual transmission versions ran a 15.2 second quarter mile. The automatic would likely run a slower quarter mile time.
Now for those Civic Si models:
The '99-'00 Civic Si (EM1) came with the B16A2, a 1.6L DOHC VTEC engine with 160hp and 111lb-ft. 0-60mph in 7.2 seconds and a 15.5 second quarter mile.
The '02-'05 Civic Si (EP3) came with a K20A3, a 2.0L DOHC iVTEC engine with 160hp and 132lb-ft. 0-60mph in 7.6 seconds and a 15.8 second quarter mile.
The '06+ Civic Si (FG2/FA5) comes with a K20Z3, a 2.0L DOHC iVTEC engine with 197hp and 139lb-ft. 0-60mph in 6.7 to 6.3 seconds and a 14.7 second quarter mile
Last edited by NOFX; Jan 29, 2011 at 02:33 AM. Reason: Added the messages I was replying to in order to clarify the thread I had replied to.
Old Jan 29, 2011 | 01:55 PM
nus_dogg's Avatar
Well, don't forget the Civic Si K20Z3. Those are the faster Si's. If you don't have any mods to back it up, you'll loose cause those 97-01 Preludes are heavier.
And no, There's not one Si that came with a 1.8L from factory. The 99-00 Si came with a 1.6L while the 03 Si and newer ones are all 2.0L(K-Series).
Old Mar 3, 2011 | 08:24 AM
olykc's Avatar
When putting a turbo in a vtec engine will you need to upgrade your cam?
Old Mar 3, 2011 | 08:33 AM
dagle's Avatar
OH.. MY... ****ING.. GOD.. GET THE **** OUT.
just when i thought this thread couldn't possibly get more unbearable to read.
Old Mar 3, 2011 | 08:40 AM
olykc's Avatar
[QUOTE F A G L E;44782899]OH.. MY... ****ING.. GOD.. GET THE **** OUT.
just when i thought this thread couldn't possibly get more unbearable to read.[/QUOTE]
bitch im trying to learn some **** so eat a dick F A G L E
Old Mar 3, 2011 | 08:52 AM
xpoint's Avatar
^^lol.
Old Mar 3, 2011 | 09:03 AM
dagle's Avatar
EVER HEAR OF GOOGLE? ****ING ***GOT.
Old Mar 3, 2011 | 09:11 AM
dagle's Avatar
google has a ****ing billion answers on the topic you just mentioned since the early 90's. I'm sure the EXACT question came up at least ONCE. how the **** do you think people boost 100% stock motors?
google that **** or read the FAQ. if its not here, it's def in the Forced Induction section. everybody tryna get spoonfed these days. ****.
