Iac valve issue
Old Jan 7, 2011 | 02:11 PM
jarol220's Avatar
Default Iac valve issue
Ok so I'm having a problem with my prelude I just swapped an f20b into it and every thing went smooth it has obd 1 injectors and an obd1 ecu and harness there are two sensors that arnt hooked up yet they are the o2 sensor and the oil pressure sensor. When ever I start the car it revs to 8k then dies back down then reves to 8k again. Any idea on what the problem is?
Thanks
Old Jan 7, 2011 | 02:42 PM
Acidcrakker's Avatar
Default Re: Iac valve issue
The oil pressure sensor just turns on when there is low oil pressure, shouldnt affect idle at all.
Not having the o2 sensor plugged in will just run the ecu in a certain ecu mode, forget if its open of closed loop.
Your issue lies else where.
Old Jan 7, 2011 | 02:55 PM
nus_dogg's Avatar
Vacuum leak? Thats odd.
boxxykiller
Oct 23, 2013 08:30 PM
j.packsb
Dec 10, 2009 10:23 AM
Lsvtecy0
Apr 14, 2008 04:57 PM
