Distributor Conversion
Old Jan 3, 2011 | 07:27 PM
stealth09's Avatar
Default Distributor Conversion
When converting from a OBDII distributor to a OBDI distributor, do you need to change the ECU, or can you still use a OBDII ECU?
What if you want to switch from a JDM OBDII internal coil distributor to a OBDI external coil distributor?
chatosf415
Oct 18, 2015 04:32 AM
minvi
Mar 7, 2011 06:04 PM
