Knock Sensor Question
Old Jan 19, 2011 | 01:05 PM
DLUDE94's Avatar
Default Knock Sensor Question
If anybody has done the H23 to F22 swap in a 92-96 Prelude(im sure there is a few, if not alot), how did mount the knock sensor? Getting ready to do swap and I'm trying to get all the information I can before I start. Also, what else is there that I need to do or look out for? Thanks
Old Jan 21, 2011 | 04:45 PM
X01Michael's Avatar
Default Re: Knock Sensor Question
knock sensor isnt needed, im assuming your getting it tuned. you can get it disabled.
Old Jan 22, 2011 | 06:22 PM
nus_dogg's Avatar
If you run the p28 chipped ECU, you won't have to hook it up because the p28 ECU doesn't come with it on the circuit board.
Old Jan 25, 2011 | 07:04 AM
DLUDE94's Avatar
What does the P28 come in? Will it kick any check engine codes?
Old Jan 26, 2011 | 08:45 PM
X01Michael's Avatar
google it. im not sure. but the p28 you can disable almost any CEL. its the most flexible ecu ive delt with.
Old Jan 26, 2011 | 09:47 PM
InvaderTrax's Avatar
Even the P12 F22 ECU doesn't require a knock sensor
Old Jan 31, 2011 | 03:23 AM
asianpoet's Avatar
i have a 99 lude, n the stock knock sensor goes from 79-170 ( depending on where u get it )
or you can purchase a honda knock sensor from a different year, and model and install it for less.. (bought mine for 30 from a 200? model civic) and changed the plug.. single wire knock sensor.
Old Jan 31, 2011 | 04:39 AM
1GPlusSH's Avatar
if there is nothing on the P28 for the knock sensor, it won't throw any engine codes
95b16civic
Mar 18, 2010 07:02 PM
memphosfinest
Mar 13, 2008 12:48 PM
96 GSR-T
Jun 30, 2006 09:31 PM
VTECLuDe96
Dec 22, 2004 09:31 PM
B20-T
Feb 19, 2003 06:39 AM
