Brake Force Distribution
Old Jan 9, 2011 | 05:49 PM
X01Michael's Avatar
Default Brake Force Distribution
6 months ago did a brake change to all 4. did one yesterday and both fronts were at 80% rear left at 40% and rear right at 5%. is there any way to manage pressure? also after my break change my BRAKE light is always on.. thanks guys.
Old Jan 9, 2011 | 07:34 PM
LUDEcidDream's Avatar
Default Re: Brake Force Distribution
abs light maybe. for the other i have no idea. was there any leaks or anything? bled properly ect?
Old Jan 9, 2011 | 07:37 PM
Kronn 98SH's Avatar
Your rear calipers are probably the cause of the issue. They tend to get "stuck". I'm surprised you didn't notice the car pulling to the right a hell of a lot.
Brake light most likely means you don't have enough brake fluid or the floater got stuck.
Old Jan 9, 2011 | 07:56 PM
minilogoguy18's Avatar
Brake light also means bad sensor on master cylinder.
Old Jan 10, 2011 | 03:31 AM
godslayer's Avatar
Always readjust your parking brake after doing the rear brakes. This is another reason your brake light may be on.
Old Jan 10, 2011 | 04:41 AM
andyz's Avatar
Air in the line that goes to a particular caliper will cause weirdness at that caliper. Under light braking that caliper will not work at all as the air will start to compress and the other calipers will do the braking. Under harder braking that caliper will suddenly grab as air is compressed as much as it can and the fluid start to pressurize at the caliper.
Old Jan 10, 2011 | 09:17 AM
Enzo15's Avatar
Did you lube the guide pins when you changed the pads?
Old Jan 10, 2011 | 11:48 AM
holmesnmanny's Avatar
If you're losing brake fluid at the same time I'm thinking the bleeder bolt might be slightly open allowing fluid out and less brake wear on that wheel.
Kennyjai
Oct 17, 2011 11:55 AM
zerogravitycrx
Apr 6, 2005 11:29 PM
216.226.142.95:27016
May 24, 2003 06:10 AM
civicboisi
Mar 8, 2003 06:45 AM
94BlackRS
Nov 28, 2002 02:43 PM
