rough start when cold
Old Feb 4, 2011 | 05:56 PM
balliso911's Avatar
Default rough start when cold
93 Vtec with 257K miles on it. Ive only owned it for 1k of those so not sure about previous maintanence history.
Was having idle surge on initial start when engine is cold. Removed and cleaned the FITV which took care of the problem. Idle seems to be fine during engine warm up and after i have been driving.
The problem i am having is only on cold start. The engine sounds like it is struggling, and then when it turns over it sounds rough during the start. After the engine is warm, i have no issues with restarting. It starts fine, and idles fine after that.
It is not throwing an engine code so i am not really sure what is causing the issue. Helms says possible coolant sensor, TDC sensor, or MAP sensor, but it also says if not showing a code for it, it probably isnt the issue.
thanks in advance.
Old Feb 6, 2011 | 07:24 AM
balliso911's Avatar
Default Re: rough start when cold
anyone?
KidDxbOrI
Jan 7, 2014 10:06 PM
ek2588
Sep 3, 2008 01:55 PM
busyychild
May 11, 2007 05:13 AM
arren123
Feb 18, 2002 01:37 PM
