1995 Prelude ABS code
Old Feb 5, 2011 | 08:13 PM
serjey15's Avatar
Default 1995 Prelude ABS code
hey guys so I just did the paper clip thing on my 1995 honda prelude vtec. and I got 1 long blink and 2 short blinks on the ABS light. So this means its code 12 I think. Does anyone know what this code means?
Please dont hate or says "read the faq!"
I read it and couldnt find code 12 thats why im posting this, if you cant help then please dont say anything.
Thanks.
Old Feb 5, 2011 | 08:45 PM
Altilude's Avatar
Default Re: 1995 Prelude ABS code
Thanks.
codes for abs are as follows:
after ignition is turned on, ABS warning light will turn on for one second, then pause for 2 seconds before blinking first code. First code number indicates main code and second code number indicates sub code. Three codes can be seat at once.
from what your saying i'm guessing:
For ABS, Main Code is 1, with Sub-Code 2 - Pump motor circuit problem, - (other component) motor relay, unit fuse, motor fuse.
Old Feb 5, 2011 | 08:50 PM
serjey15's Avatar
motor relay, unit fuse and motor fuse are good, I just checked, do you know how to check pump motor circuit?
Old Feb 5, 2011 | 10:36 PM
dagle's Avatar
I think Kronn_98SH had this issue in the past
Old Feb 6, 2011 | 10:21 AM
serjey15's Avatar
So you dont know what the problem could be?
97+ preludes are obd2, it could be something different.
Old Feb 6, 2011 | 11:29 AM
Yuyodrift91's Avatar
I see what you did there....
Old Feb 6, 2011 | 08:11 PM
serjey15's Avatar
yeah i know. look at my sig
Alcatrax30
May 7, 2015 01:36 PM
paniaguae640
May 27, 2008 01:42 PM
arren123
Jun 18, 2007 04:00 AM
b20acura
Jun 17, 2007 10:53 PM
