Head work done
Old Feb 7, 2011 | 08:26 AM
Nocture's Avatar
Default Head work done
Beautiful!
Old Feb 7, 2011 | 08:48 AM
serjey15's Avatar
Default Re: Head work done
I dont know man looks pretty good, the ports look clean. Just clean it up as much as possible with hot soapy water, get all the gasket crap off, install the head with good gaskets and do everything right and see how it runs.
Old Feb 7, 2011 | 12:22 PM
Nocture's Avatar
Excellent
Old Feb 7, 2011 | 12:29 PM
q16racer's Avatar
Why dont you call the guy who did it instead of getting second hand internet opinions?
Old Feb 7, 2011 | 12:37 PM
Nocture's Avatar
Thanks bro!
Old Feb 7, 2011 | 03:44 PM
Ledslnger's Avatar
When I got my heads back for a SB Ford they were clean. I recently picked up a reman H23 head from a local machine shop and it was spotless and ready to install. They normally go through a hot tank\cleaning process and that stuff should come off fairly easily when they pull it.
Old Feb 7, 2011 | 04:11 PM
q16racer's Avatar
hot tanking does not make a part look new. Thats what acid dipping and sand blasting is for.
Old Feb 7, 2011 | 06:02 PM
NAH2B's Avatar
i would not recomend acid dipping your head or block, and sandblasting is the last thing you would want to do.
if your gonna do any kind of blasting you want to soda blast, as it will disolve and wash away.
Old Feb 7, 2011 | 07:13 PM
serjey15's Avatar
coca cola blast?
Old Feb 8, 2011 | 04:32 AM
1GPlusSH's Avatar
ditto
when i had a port and polish done, they sandblasted mine...it didn't turn out so good. if i can find my old head in storage, i'll post pics.
Old Feb 8, 2011 | 04:01 PM
NAH2B's Avatar
Originally Posted by serjey15
coca cola blast?
no
any type of "blasting" uses different types of media such as sand or glass beads, crushed walnut shells, etc.
the best thing to use when it comes to engine components is baking soda because it can be washed out of all the oil passageways afterwards very easily since it disolves in water.
sand, glass beads etc. will NOT come comepletely out no matter how hard you try. so when you have your head/block sandblasted or glass beaded you end up w/ sand/glass in your oil and throughout your engine.
WishinItWas
Aug 22, 2007 02:58 PM
7808
Mar 20, 2007 06:13 AM
sporkcrx
Jul 26, 2003 12:57 AM
rasta420
May 21, 2003 08:15 PM
275Performance
Dec 21, 2002 08:11 PM
