Coolant problems? h22a eg
Old Jan 16, 2011 | 06:55 PM
cas9889's Avatar
Default Coolant problems? h22a eg
I have a 94 hatch with an h22a in it I am running a mizu radiator. I got the swap started last night. I filled the radiator and started it let it run for a little bit then topped the system off. Started the car again and turned the heater on full blast then opened the bleeder valve. I let it run until my temp gauge got halfway up on my cluster. This was about 15 minutes. No fan kicked on and the top of the radiator was warm and the bottom was ice cold. Its only a halfsize radiator. I still continue to open the bleeder valve and get air out of it, but my block gets a lot hotter than I would like it to. Meaning I touch it and I cant keep my hand on it for more than 2 or 3 seconds. I have about a gallon and a half of coolant in it. how can I tell if there is coolant in my block and if it is actually flowing?
Old Jan 17, 2011 | 09:00 AM
cas9889's Avatar
Default Re: Coolant problems? h22a eg
bump 46 views and nothing?
Old Jan 17, 2011 | 10:59 AM
nus_dogg's Avatar
Thermostat probably stuck close?
You can pop the radiator cap off when its cold, start it up, and you should sorta see the coolant flowing.
Old Jan 18, 2011 | 10:22 AM
Blacksi76's Avatar
I'd check the thermostat as well, i have always had a hard time with my H22 setup bleeding coolany system and getting all the air out....
EGcivic_95
31
Jan 29, 2011 06:09 PM
cas9889
Jan 17, 2011 05:26 PM
96Integ
Mar 29, 2009 06:11 PM
frank358fr
Feb 9, 2007 09:46 AM
superturboprelude
Aug 29, 2004 10:14 AM
