Back from the Dyno...
Old Sep 22, 2003 | 04:10 PM
PrecisionH23a's Avatar
Default Back from the Dyno...
Last friday my friends and I headed out to Balanced Performance in Sugar Hills, GA for a dyno tune as well as the Nopi Nationals. For any of you that are looking for a GREAT dyno tuner, I highly recommend Ed at Balanced. He does a great job and he is more then happier to sit down and show you how the tuning process goes. I would also like to state to the people out there that want '400whp' that it requires a LOT more then just buying pistons, sleeves, rods, and a 60-1 turbo. Plan on putting your blood sweat and tears into your project and always expect the unexpected. Or you can always pay someone to do it for you... but you do not get the satisfaction of knowing that YOU did it yourself.
With that out of the way... The car was tuned on race gas for 20psi. For those of you that want high horsepower h series motors, i do not recommend running 93 octane above 375-390whp. This would be due to the mean specific brake consumption (msbc) of the h series motor as well as trying to avoid detonation. Around the 390whp mark we encountered a small misfire. So we then decided to add some 103 octane as well as gap the plugs from a .028 to a .025. First run after that increased 20whp. I originally planned on running straight 116 octane right around 25psi or so, but we decided to call it quits since our group was there from 10am-5pm. Maximum power was 423.3whp and 360 torque at 20psi. This was with relatively low timing and without even playing with cam gear settings. I could have squeezed a bit more power (450-475whp level) by advancing the timing, running 116 octane, and playing with the cam settings but we decided to stop while we were ahead. Plus, the rubber 90deg boot popped off everynow and then under the 20psi pulls. That will be soon solved by adding a 90 deg elbow welded to the compressor of the turbo in the near future.
A brief overview of the set-up includes the following:
Engine Management
Hondata Stage s200 Engine Management
GM 3 bar map sensor
Apexi AVC-R Boost Controller
Greddy Turbo Timer
Greddy Boost and EGT gauges
MSD 6AL ignition
MSD HVC coil
Fuel
RC Engineering 720CC Injectors
Earl's -8an Steel Braided Feed Line
Earl's -6an Steel Braided Return Line
AEM High Pressure Fuel Rail
Paxton adjustable Fuel Pressure Regulator with Fuel Gauge
Paxton Fuel Filter
Walbro In-Tank 255 High Pressure Fuel Pump
Engine
Precision SC61 T04e compressor .58 a/r t4 turbo with vband
LoveFab SST Equal Length Tubular Manifold
Custom 3" v-band downpipe
Custom Mandrel Bent 3" exhaust with Apexi n1 cannister
PWR 24"x8"x3" Core Intercooler
2 1/4" intercooler piping
HKS Super Sequential blow off valve
Tial 35mm wastegate
GSR Fluidyne Radiator with Slim-Fit dual fans
Custom ARP head studs
Gude Racing Cylinder head Package
-Oversided Gude Throttle Body
-Ported/Polished intake manifold
-Ported/Polished Cylinder Head
-Racing grind valve job
-Turbo Camshafts (Intake and Exhaust)
-custom front motor mount
Custom 88MM CP Pistons 9.0:1 Compression
Swain Technology Coated pistons
-Top Gold Coat
-PC-9 sideskirt coat
-Wiseco 88mm piston rings
Crower 4340 Steel Billet Connecting Rods
Crower 220ksi Rod bolts
Honda OEM Rod/Main Bearings
Polished Crank
Darton Iron Ductile Sleeves with copper o-ring
OEM headgasket
Custom Steel Braided Ground Wires
Greddy Oil Catch Can
NGK BCPR7ES spark plugs
Keep in mind there has been major modification to the engine bay/suspension components/etc to allow for proper fitment of certain parts.
A few pictures:
(thats me in the pimp *** hawaiian pants)
Video of the dyno (2.6MB):
http://people.clemson.edu/~lan...p.mpg
-not the best video in the world, but it will do for now. I wish I would have taken more video's with my camera but I was paying more attention to the tuning process as well as monitoring the dynojet programs.
Special thanks-
Cody at LoveFab.com
Mike at MotorMatrix.com
Integra707 for the IC
XES for all of his help and pointers
All of the Prelude and Forced Induction guys who have helped me out greatly
In the future to come-
Portflow head
Larger Valves
40mm wastegate
Sheetmetal Intake Manifold
880cc injectors
25 shot of NAWWZZZ
500whp badge
Modified by GudeH23a at 12:00 PM 9/27/2003
Old Sep 22, 2003 | 04:17 PM
Que_Lude's Avatar
Default Re: Back from the Dyno... (GudeH23a)
Man, that's one SWEET H22A! Great numbers and tech info
Old Sep 22, 2003 | 04:24 PM
4bidden's Avatar
Default Re: Back from the Dyno... (Que_Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Que_Lude &raquo;</TD></TR><TR><TD CLASS="quote">Man, that's one SWEET H22A! Great numbers and tech info </TD></TR></TABLE>
Yea, too bad its a H23A1, huh?
Old Sep 22, 2003 | 04:28 PM
90Integra's Avatar
Wow very nice lude!!!!
Old Sep 22, 2003 | 04:39 PM
Nick M's Avatar
Default Re: (90Integra)
very very nice
Old Sep 22, 2003 | 05:08 PM
prelude beast's Avatar
Default Re: (Nick M)
nice
Old Sep 22, 2003 | 05:11 PM
AndyD's Avatar
Default Re: (T4 prelude beast)
Very nice!! Did you relocate the battery to the trunk?? I want to do that.
Man, I missed you at NOPI!!!
Old Sep 22, 2003 | 05:31 PM
Default Re: (AndyD)
Yep, the battery is located in the trunk. I am going to order a battery box with a kill switch from summit in the near future so I am allowed to drag race it. I will also be adding a roll cage in the near future as well.
Maybe we'll meet up next year, haha
Old Sep 22, 2003 | 05:33 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (GudeH23a)
god damn, thats some crazy numbers.
beautiful engine!
Old Sep 22, 2003 | 05:49 PM
piotrush's Avatar
all I can say is
Old Sep 22, 2003 | 05:52 PM
JBG's Ferio's Avatar
Default Re: Back from the Dyno... (piotrush)
wow man that is awesome.
Old Sep 22, 2003 | 05:53 PM
hondaZvic's Avatar
Default Re: (Sticky Tires)
WOW!!!!!!! u have done an excellent job!!!!! keep it up.
im gessing u havent hit the track recently? or have u? get us some times up here
keep up the good work man.
Old Sep 22, 2003 | 05:56 PM
PetroGuyX's Avatar
holy **** those are some BADASS numbers on an h23a1 dude, how much cash was put into that bad boy and how many hours?
Old Sep 22, 2003 | 06:07 PM
machinehead's Avatar
all i can say is holy shizzle mah nizzle!!!!!
Old Sep 22, 2003 | 06:10 PM
rjr162's Avatar
Default Re: (machinehead)
out of curiousity, did you do anything to the drive train, such as upgraded axels etc? Just curious if you didn't do you think the stock CV's and other parts are going to take 430hp with slicks? I know alot of the honda drive train (ok well tranny) are damn good, just wondering which parts and how good.
Old Sep 22, 2003 | 06:20 PM
Teen Heartthrob's Avatar
Default Re: (rjr162)
not to sound like a noob, but what is that big light blue thing in the engine bay...?
Old Sep 22, 2003 | 06:22 PM
* B A N N E D *
Default Re: (Teen Heartthrob)
i think thats a fan to cool off the engine. and no it's not a mod.
Old Sep 22, 2003 | 06:25 PM
PetroGuyX's Avatar
it's not to cool off the engine, it's a working fan, just cools you down while you're working lol, the matco guy sells them, they're called blue something or others, they're work fans
CHK4TIX's Avatar
very nice, i wish i had your dedication
Old Sep 22, 2003 | 06:26 PM
* B A N N E D *
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">it's not to cool off the engine, it's a working fan, just cools you down while you're working lol, the matco guy sells them, they're called blue something or others, they're work fans </TD></TR></TABLE>
well, close enough.
Old Sep 22, 2003 | 06:48 PM
del_parker's Avatar
heh, did you see the civic that put down 438 on the mustang dyno with the tires losing traction?
what kind of axles are you using?
Old Sep 22, 2003 | 07:35 PM
LudEcrous's Avatar
Default Re: Back from the Dyno... (del_parker)
You and XES are my h23 heros!!
I didn't know Will hooked you up with the IC...Integra707
Old Sep 23, 2003 | 08:44 AM
Default Re: (hondaZvic)
No I have not had a chance to make it out to the track yet and I probably won't until I get some axles that can take the power that I'm putting down. The transmission has been rebuilt with all OEM gears/synchro's and I have also added the quaife LSD.
The 'blue thing' on the dyno is a fan used to keep intake manifold temperatures down.
Old Sep 23, 2003 | 08:49 AM
hondaZvic's Avatar
ya... what kind of axles are u planning on getting?
Old Sep 23, 2003 | 08:52 AM
Finest's Avatar
WOW! Props to you and the H23!
BTW, at which rpm do you start seeing boost? Or full boost?
Excellent job, like always!
