VTEC wont switch on (sometimes?)
Old Sep 25, 2003 | 06:55 PM
fast4w$'s Avatar
Default VTEC wont switch on (sometimes?)
My VTEC has been acting up lately. The first 15-25 min of driving are fine with normal VTEC function. driving for long periods i notice that i get a muffled thumping sound coming from the engine and NO vtec, (it seems like its trying, but cant engage...) After a few times it just revs like an H22A with no VTEC. Could it be the vtec solenoid?
Old Sep 25, 2003 | 07:22 PM
AndyD's Avatar
Default Re: VTEC wont switch on (FaS4wS)
The VTEC solenoid going bad??
Old Sep 25, 2003 | 07:26 PM
fast4w$'s Avatar
Default Re: VTEC wont switch on (AndyD)
i'm hearing a very loud thumping and fluttering sound from the engine when it tries to go into vtec....
Old Sep 25, 2003 | 08:09 PM
satan_srv's Avatar
so you hear no VTEC whatsoever?
Old Sep 25, 2003 | 08:26 PM
ChargedLude97's Avatar
No cel's when it does it?
Old Sep 26, 2003 | 04:49 AM
caliriptide's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaS4wS &raquo;</TD></TR><TR><TD CLASS="quote">My VTEC has been acting up lately. The first 15-25 min of driving are fine with normal VTEC function. driving for long periods i notice that i get a muffled thumping sound coming from the engine and NO vtec, (it seems like its trying, but cant engage...) After a few times it just revs like an H22A with no VTEC. Could it be the vtec solenoid?</TD></TR></TABLE>
Ok...
1) Did you check you oil pressure in the head?
2) How often do you change your oil???....The journals(spell) on you second set of cams(vtec) could be sticking, getting clogged? Have had it happen to a friend b4.
3) Could be the solenoid. I would take it apart, check to make sure the Piston is not getting jammed/stuck in the cylinder. Clean it all out. (3) bolts hold the solenoid on to the assb. Then another (3) unbolts the assembly from the head.
Just check everything over.
Old Sep 26, 2003 | 02:08 PM
fast4w$'s Avatar
Default Re: VTEC wont switch on (caliriptide)
Very good advice...I will check all these items and get back to you.
For the record...
1. vtec DOES work, just not all the time. When the engine is operating for more than 45 min to an hour, vtec tries to come on, but cannot, making a really wierd sound thumping sound. Is heat an issue?
2. funny you talk about the second cam not hitting vtec. I notice that when vtec was working properly, it (vtec) wouldnt hit as hard as some of my buddys ludes...and i have more mods!! then when the car was good and warm...vtec would SLAM very hard...
3. I'm wondering if the second cam is sticking...it seems this is ALSO whats goin on on top of vtec not working.
I will check the whole system an let you guys know...THANKS
Old Sep 26, 2003 | 03:04 PM
HotWheelz's Avatar
OIL OIL OIL...
if cam can't "STICK"... and their more than enough oilpressure to blow any chunk of **** in the way to your assemblies...
check your oilpressure and oil if the selenoid was bad it would throw a light, because the ecu constantly looks for it...
A cam can't stick, if so it would strip the teeth of your timing belt and possibly destroy the motor by collision with valves... something else is the problem but check the top ones.
Old Sep 26, 2003 | 06:36 PM
fast4w$'s Avatar
Default Re: VTEC wont switch on (HotWheelz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz &raquo;</TD></TR><TR><TD CLASS="quote">OIL OIL OIL...
A cam can't stick, if so it would strip the teeth of your timing belt and possibly destroy the motor by collision with valves... something else is the problem but check the top ones.</TD></TR></TABLE>
I have a strange feeling we are on to something...things are ok with my motor right now...but not for long it seems...thanks guys, i'll let you know what i come up with...
G'D_DC5
10
Jul 23, 2007 10:40 AM
lmiguelvv
Oct 19, 2004 06:55 PM
97dc2
Sep 23, 2004 12:00 AM
THE SOUND OF VTEC
Apr 30, 2002 12:20 AM
