Battery Light on
Old Sep 22, 2003 | 04:00 PM
fe519's Avatar
Default Battery Light on
I have a weird problem. I needed to change the alternator today and after I was done, the battery light came on. It turns out that I needed a new battery also and I also changed that. I drove it for the whole day already and it is still on. Can someone tell me WHY the stupid light is still on? I checked all the connection, the power, ground, etc. and everything seems to be fine. Thanks for the help.
Old Sep 22, 2003 | 04:44 PM
TRN's Avatar
TRN
Default Re: Battery Light on (fe519)
I don't think that would be something that takes a few drive cycles to reset...odd
Old Sep 22, 2003 | 04:57 PM
4bidden's Avatar
Did you tension the belt enough? It could be slipping.
Old Sep 22, 2003 | 05:39 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Battery Light on (4bidden)
try resetting the ECU. the last time my batt. light came on my alternator died.
Old Sep 22, 2003 | 06:00 PM
rjr162's Avatar
Default Re: Battery Light on (Sticky Tires)
i was going to say make sure all your connections on the alternator are good and tight. Typically the battery light will come on if it senses the alternator not charging the battery. This can also be tripped falsely by a loose connection at the "monitoring" plug of the alternator
Old Sep 22, 2003 | 08:56 PM
fe519's Avatar
Default Re: Battery Light on (rjr162)
everything is tight... and the belt is tight... do you guys think the alternator i bought is bad?
Old Sep 23, 2003 | 03:25 AM
Behan's Avatar
did you check the voltage the new alternator is putting out? check voltage on the alternator and at the battery.
haywyre
Oct 9, 2008 12:27 PM
da9pwnsu
Jan 19, 2007 12:12 PM
bleedblue94
May 20, 2006 07:57 PM
Alexnaderkeith
Sep 10, 2003 08:32 AM
