lean problem?
Old Sep 25, 2003 | 04:05 PM
tea's Avatar
tea
Default lean problem?
Ok here is the story. I had an f22b JDM Si motor and it had bad hesitations periodically. Finally it snapped a timing belt and drove my valves into my pistons on the freeway (ugly site). Well I decided to get an h22 and install it hoping that the hesitation or bogging would go away. I was wrong. I recently hooked up a a/f gauge (autometer) which took me forever to install because there were no lights showing until I gas it to about 7k rpm and then I see two red bars indicating lean then they would disappear. I see this as a big problem... why is my car running that lean? For reference I replaced the starter, fuel pump/filter/regulator, plugs and plug wires, and dizzy cap and rotor. Engine is pretty much stock with intake and exhaust. Thanks for the help.
Old Sep 25, 2003 | 04:16 PM
Cottonwoodz's Avatar
Default Re: lean problem? (tea)
How did you wire the gauge?
Old Sep 25, 2003 | 06:05 PM
tea's Avatar
tea
Default Re: lean problem? (Cottonwoodz)
I tried both directly to the o2 sensor and ecu (solid white wire). same lean readings.
Old Sep 25, 2003 | 07:01 PM
Jeff33S's Avatar
what ecu are you using... fuel setup...?
What fuel wise did you use off the old motor anything?? Injectors?? It maybe just the gague how do the plugs look?
-Jeff-
Old Sep 25, 2003 | 07:17 PM
tea's Avatar
tea
Default Re: (Jeff33S)
I use the p13 Jdm h22 ecu. complete change-over, all h22 parts. The plugs were pretty white like a lean condition would look like.
jdm knight
Aug 7, 2006 06:27 PM
raylude
Oct 15, 2004 10:59 PM
WeaponR
Apr 26, 2004 11:45 PM
Kazz
Apr 24, 2003 01:26 PM
servion
Jan 17, 2002 11:15 AM
