spark plug gap
Old Sep 22, 2003 | 05:16 PM
preludesh012001's Avatar
Default spark plug gap
i need to install some new plugs to replace my bosche platnums. I got some of the NGK 1 step cooler plugs for the JRSC. DOes anyone know what the gap is suppose to be on those.
Old Sep 22, 2003 | 07:31 PM
CHK4TIX's Avatar
Default Re: spark plug gap (preludesh012001)
.25
Old Sep 22, 2003 | 07:37 PM
sharkcohen's Avatar
Default Re: spark plug gap (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">.25</TD></TR></TABLE>
That's a pretty large gap, I'm sure you meant .025
Many JRSC luders are running gaps between .030-.035. You'll need to play around with the gap size (preferably on a dyno) to find what is optimal for you. I'm running .028 with 9 psi.
Old Sep 23, 2003 | 04:35 AM
CHK4TIX's Avatar
Default Re: spark plug gap (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Many JRSC luders are running gaps between .030-.035. You'll need to play around with the gap size (preferably on a dyno) to find what is optimal for you. I'm running .028 with 9 psi.</TD></TR></TABLE>
sorry, i did mean .025
Old Sep 23, 2003 | 09:05 AM
TraKtioN's Avatar
What are the tradeoffs with having a large gap vs small?
Old Sep 23, 2003 | 12:30 PM
is it better to be at 0.35 for JRSC than .025?
I dont have a dyno anywhere around where i live, how would it affect it?
Old Sep 23, 2003 | 05:03 PM
sharkcohen's Avatar
Default Re: spark plug gap (TraKtioN)
The larger the gap, the more likely the spark will be "blown out" during boost, causing problems with igniting the mixture.
Old Sep 23, 2003 | 05:04 PM
sharkcohen's Avatar
Default Re: (preludesh012001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludesh012001 &raquo;</TD></TR><TR><TD CLASS="quote">is it better to be at 0.35 for JRSC than .025?
A safe gap would be .030.
How do you plan on making sure you are not running too lean if you don't have a dyno with a wideband near you??? I hope you plan on installing a fuel pressure gauge, as fuel pressure IS your fuel delivery system during boost. Setting the fuel pressure properly is CRITICAL.
Old Sep 23, 2003 | 05:34 PM
TraKtioN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">The larger the gap, the more likely the spark will be "blown out" during boost, causing problems with igniting the mixture.</TD></TR></TABLE>
then why dont you just make a small gap in the first place?
Old Sep 23, 2003 | 05:47 PM
sharkcohen's Avatar
Well, considering that the stock gap is .044, that is what we are discussing doing.
fyre
Nov 16, 2006 05:52 AM
DeDonDeRosa
Nov 12, 2006 10:42 AM
DeDonDeRosa
Mar 8, 2006 04:04 PM
vgsr
Aug 22, 2005 04:25 PM
TOFU.man
Jan 15, 2004 03:16 PM
