aem cia installation problem
Old Sep 22, 2003 | 01:54 PM
blueluder's Avatar
Default aem cia installation problem
Ok ive got everything off cept the resonator. read earlier about lots of "hidden bolts but man there is just one i cant get to. if your in the weel well and you look at the resonator , its on the right side bolted to some other thing. lol sorry about bad description but its the only bolt that i cant see to get some any angle without taking off my bumper. its kinda towards the top of the res tube and closer to the front of the car. im sure its the only thing left to unbolt, then ill have this damn thing done in 5 min.
Old Sep 22, 2003 | 02:02 PM
577HondaPrelude's Avatar
Default Re: aem cia installation problem (blueluder)
Remove the side turn signal light. Then use one of them swivel socket thingies with an extension. That's what I had to do.
Old Sep 22, 2003 | 02:08 PM
blueluder's Avatar
Default Re: aem cia installation problem (57STS)
maybe just need more tools . and another off topic question, anyone have a solution to a squeaky clutch.
Old Sep 22, 2003 | 02:15 PM
NXBen's Avatar
Is it a 4th or 5th gen? On my 4th gen, I was able to get at it by removing the turn signal. I could just barely get a socket on the bolt (10mm, I believe) and was able to turn it about 1/8 of a turn at a time. It was painful, but I got it. I had one hand in from the fender side and the handle of the wrench sticking out by the turn signal. Good luck.
My clutch is also squeaking, so I'd like to know about that too!
Old Sep 22, 2003 | 02:16 PM
if it's just the peddle then hit it with some WD40. If it's the actual clutch, then I don't know other than to tear into it.
Old Sep 22, 2003 | 02:19 PM
NXBen's Avatar
At least with mine, it's coming from under the hood (I have a '93 Si, BTW). The clutch feels fine and it was just replaced not too long ago. I doubt it's the clutch itself. It looks like it's cable driven, so it's probably something in the cable.
Old Sep 22, 2003 | 02:21 PM
blueluder's Avatar
Default Re: aem cia installation problem (NXBen)
it just started raining
ill have to try the signal tonight or tomorrow"dang cant show it off tomorrow at school "
Old Sep 22, 2003 | 02:24 PM
Jagan'92's Avatar
You should be able to take off the two or three bolts under the bumper on that side - loosening the bumper so you can pull that out and slide your ratchet in there (from the wheel well side) to that last bolt. Take off the side marker so you can look in there and see what you're doing.
It's bolted to a little metal bracket, and all of it will come out when you loosen the bolt. then rip that **** out. *kapow*
Old Sep 22, 2003 | 05:44 PM
blueluder's Avatar
Default Re: aem cia installation problem (Jagan'92)
bumper things worked thanx i got it all in cant wait to try it tomorrow
ZekeComa
Oct 4, 2012 08:16 PM
prelude964
Sep 18, 2005 01:27 AM
95PreludeSi
Jul 20, 2005 08:21 PM
spyz34
Mar 1, 2004 04:12 PM
vtecjb
Nov 15, 2003 04:40 PM
