clicking noise from engine
hey everyone, i was wondering you guys know whats wrong if the engine makes a clicking noise....it sounds kinda like the valves, but not sure....any ideas?
Re: clicking noise from engine (shyboy_02)
I have a similiar problem, only at low rpms however. So last friday, i did a compression check and it turns out cylinder #4 was at 110, when ideally, for 2nd gens, it should be between 156 and 128 psi. So, the clicking attributed with low cylinder compression leads me to beleive that its my valves. Most likely the same with you. Hope this helps.
Re: clicking noise from engine (Hank the retard)
hey thanks for your response....i think its my valves also...i'm trying to sell it anyways, so i'll probably just leave it cause its still running good and everything so....well, thanks again....
Re: clicking noise from engine (57STS)
I have this clicking noise, it was there before my engine build, and is still there after. My header was cracked, but I had it welded up. It usually goes away after the car is fully warmed up too. Kinda wierd, but I have no idea what it is.
ElectronBlue00
12-16-2013 07:21 AM
