ECU question
Old Sep 21, 2003 | 04:31 PM
4bangin's Avatar
Default ECU question
I just bought a 93 Prelude S with an h22a4 swap out of a 97. It runs good, but when I hit the stock rev limiter around 6300 the motor sounds like it still has alot left, and there is no vtec. I was told that I need a p13 ECU for everything to work properly, is this correct? Just wanted to make sure before I started spending money. Also how hard is it to wire one of these up?
Thanks!
Old Sep 21, 2003 | 04:51 PM
ziggity's Avatar
Default Re: ECU question (4bangin)
you are running in limp mode bud
check your wiring for the swap especialy the vtec soleniod and see if you can get vtec working cause stock fuel cut is 7600 i believe
you may be right about using a p13 becuase i didnt have to a swap mine came stock
Old Sep 22, 2003 | 05:47 PM
4bangin's Avatar
Default Re: ECU question (ziggity)
How should it be wired? All I noticed were 3 wires hanging off not hooked up to anything.
Old Sep 22, 2003 | 09:35 PM
Qfactor's Avatar
three wire maybe it's the VSS does your speedo work.
Old Sep 23, 2003 | 01:32 AM
see_our_vtec's Avatar
Default Re: ECU question (Qfactor)
pull your ecu out and look at it and see what it says first. see if it's a p13 or not. then tell us.
Old Sep 30, 2003 | 08:17 AM
4bangin's Avatar
Default Re: ECU question (JDMlude92)
Sorry for the delay. The ECU in there now says P12.
Old Oct 2, 2003 | 12:34 AM
well thats your problem. you don't have vtec. it's not wired for vtec and your car isn't running right. whoever did your swapped rip'd you off. i'd go after them.
Old Oct 3, 2003 | 01:00 PM
4bangin's Avatar
I know that I don't have vtec and it isnt running right, I was just wondering if swapping the ECU will fix this problem, and if not what else do I need to do?
I bought with the motor in it, have no idea who did the swap.
Old Oct 3, 2003 | 04:53 PM
Daboi630's Avatar
i got a p13 ecu for you. but its OBD I. do you have the harness? or your running an OBD II ecu?
Old Oct 4, 2003 | 08:35 AM
satan_srv's Avatar
Default Re: ECU question (Daboi630)
Yes get a OBDI P13 and run the VTEC wires to the right pins and you're good to go.
That low cam must sound terrible at 6000rpms hehe
Old Oct 4, 2003 | 11:13 AM
4bangin's Avatar
Default Re: ECU question (satan_srv)
Thank you sir Yeah, it isn't pretty.
Old Oct 4, 2003 | 06:53 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bangin &raquo;</TD></TR><TR><TD CLASS="quote">Thank you sir Yeah, it isn't pretty.</TD></TR></TABLE>
just remember you'll have to run he wires for VTEC solenoid, VTM and some others? I can't remember.
Stray
Mar 24, 2007 01:08 PM
BlUAc
Sep 6, 2006 09:32 PM
Nyquil_Accord
Sep 28, 2004 09:36 PM
04accordV6
Sep 10, 2002 07:11 PM
