Mirror problem
Old Sep 25, 2003 | 07:58 PM
naujcdl's Avatar
Default Mirror problem
this is my mirror from a picture i took of it when i just got the car.
some of you may say, it isnt bad at all, but trust me it looks bad when close or far.
the problem now is that i don't know how to take the mirror apart and just see what could be wrong with the attachment/bracket...???, to the mirror. when i switch the mirror to the right on my controls on my door, it sounds like it is moving, but it is not, so basically whatever is holding the mirror to the motor inside the mirror is missing a part or something.
The question is: has anyone ever had any problems as such...if so what did u do about it? replace the motor, try to fix it? i know for a fact that i will be ordering the mirror "shell", painted from http://www.hondaautomotiveparts.com , but i need to know for sure that is all i need.
Also, the body switch is the turn signal lever, if you turn your steering wheel to normal and the lever doesn't go back to its normal position, is it just the body switch or is there something else i need to check??
Thanks for your help.
dk015
Jul 24, 2015 08:15 AM
myfirstdc2
May 7, 2007 07:03 AM
S2tripleO
Honda S2000
Jul 16, 2006 11:37 AM
BlueG3Teg
Dec 6, 2004 09:39 PM
wyldbil
Jul 3, 2004 12:43 PM
