timing + or - how much???
Old Nov 9, 2003 | 09:27 PM
H22A EG6's Avatar
Default timing + or - how much???
i have 1994 H22A in my 1993 hatch and i wanted to know how much i should retard or advance my timing if i were to run 110 octane fuel with the following mods
-FACTORY LSD
-SHORT AIR INTAKE
-WALBRO 255LPH FUEL PUMP
-AASOC ALUMINUM LIGHTENED FLYWHEEL
-ACT EXTREME CLUTCH
-APEXi N1 CAT BACK
-FREE FLOW CAT
-PLACE RACING MOUNTS
-PLACE RACING AXELS
thanks any help is welcomed!
Old Nov 9, 2003 | 10:00 PM
Eddiebx's Avatar
Default Re: timing + or - how much??? (H22A EG6)
hmmm there's really no definite answer to that, but I have found that the few h22a's I've tune liked about 20-22 degs of timing, that was on pump gas like 93 or so. And thats with a p13 ecu.
PrecisionH23a's Avatar
Higher octane fuel burns leaner allowing you to advance your timing to squeeze out a bit more horsepower. As far as how much you should advance it, I really wouldn't screw with it unless you are running hondata or some other EMS that allows you to fine tune your ignition tables.
Based on your set-up, I doubt you will benifit much from running 110 octane. The only thing you might get is a fouled 02 sensor in the process.
Old Nov 9, 2003 | 11:57 PM
marshdoggg's Avatar
Default Re: timing + or - how much??? (GudeH23a)
stock timing is 15 +/- 2 degrees, i wouldnt mess too much with that personally without a dyno and maybe hondata to have control...
Old Nov 10, 2003 | 05:10 AM
SKDRCR's Avatar
Default Re: timing + or - how much??? (marshdoggg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshdoggg &raquo;</TD></TR><TR><TD CLASS="quote">stock timing is 15 +/- 2 degrees, i wouldnt mess too much with that personally without a dyno and maybe hondata to have control...
I would definately get it dyno'd b4 you mess with the timing
1990DA
Apr 10, 2006 11:00 AM
Rishiras
Mar 28, 2006 08:26 PM
X2BOARD
Apr 13, 2005 12:57 PM
SuicideSlide
20
Jan 5, 2004 07:36 AM
