Belt for NO AC in a 5th gen
Re: Belt for NO AC in a 5th gen (Trbospnkr)
Oh really the smallest 6 rib belt will work (with in reason ) and what accord dx belt is it. i.e. crank to alternator crank to P.S.
Come on being specific helps sometimes.
just take a piece of string and measure where you have to have the belt run without the A/C pulley and take the string into the shop and say you need a belt this long.....when its in a circle....we did this with my friends Eclipse and Napa helped us out alot
Re: (RAB)
You want specific eh....
get the in the car, turn it on, drive to autozone, look at their belts, find the shortest, 6rib belt you can find, , purchase it, put it on the car..
Do you want to know which wrenches to use?
Trust me, the distance is EXTREMELY short.. I got the shortest belt, and its still almost too long..
I guess I could be nice and look at the part number of the one that on my racecar now..
Re: Belt for NO AC in a 5th gen (TeinPrelude)
Of course no one cares now but when they're taking out their AC they will. Anyways. I attained an accurate measurment of the potential belt with no AC compressor on and it seems to be 37"-38" FOR A 5th GEN. Corey and Satan-SRV have said there's are 35-36" but they have a 4th gen. As for finding a replacement belt Autozone is the leading supplier.
Autozone carries Kelly Springfield belts and I got and 37" and 38" they most likely have a 36" as well. Oh and Yes they are 6 ribbed.
Re: Belt for NO AC in a 5th gen (Honda318dx)
take the belts off... take a string and rap it like it was a belt... then mark the string.. measure the string... count the ribs that hte pulley needs... problem solved.
Re: (JDMlude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 »</TD></TR><TR><TD CLASS="quote">92 honda prelude 2.2 liter without ac.
aka the prelude s.
not true the f22a crank pulley is a different size.
RAB I said to get the Gates 360 belt aka 36". It's the same as 4th and 5th gen, same pullies.
aka the prelude s.
Re: Belt for NO AC in a 5th gen (BoostedH23a1)
i forgot how long mine was, didn't measure it. just took the length of string to the store and got a belt that was as close to that length as possible.
Re: Belt for NO AC in a 5th gen (JDMlude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 »</TD></TR><TR><TD CLASS="quote">joel. we just got mine. and mine works perfectly fine using the s belt</TD></TR></TABLE>
Well BOO! I must admit I haven't installed the belt..it's sitting in my back seat...I have a 4 rib belt on there now and I don't know that one
Re: Belt for NO AC in a 5th gen (satan_srv)
i'm sure i could even get a smaller belt on that you guys are talking about. but i just didn't want to get the belt too tight and not be able to adjust the tension on it. but it's a pretty decent fit if i say so.
Well the removal went rather smoothly BTW I used a 37" 6 ribbed belt the 36 would not budge even with the tensioner threaded competely OFF. No ill affects so far, the real test is if I have dead battery in a few days.
I removed the
AC compressor
condensor
condensor fan
dryer canister thingie
lines
and compressor mounting bracket.
I removed the
AC compressor
condensor
condensor fan
lines
bluecivic107
09-16-2004 06:44 AM
03, 522k6, 5th, ac, accord, air, altenator, alternator, belt, compressor, conditioning, gen, prelude, removal, shortest
