97lude Engine power los
Old Nov 8, 2003 | 09:36 PM
yozausa's Avatar
Default 97lude Engine power los
hey guys need help!! i'm driving on the freeway and suddenly my engine died . the rpm dropped to zero and the steering became heavy that's when i realize that i'm in trouble .so i pulled over right away. i recently replaced all the belts so i pop the hood i thought it's the belts but the belts are fine. I turned the ignition and the car started like nothing happens. Does anyone had a problem like this before. Any info or suggestion is appreciated...thanks!!!!!
Old Nov 9, 2003 | 12:54 PM
Mikeyslude's Avatar
Default Re: 97lude Engine power los (yozausa)
Ignition Switch is what it sounds like. I had the same issue in mine and it is a Recall. Contact Honda and they'll fix it.
Old Nov 15, 2003 | 08:42 AM
yozausa's Avatar
Default Re: 97lude Engine power los (Mikeyslude)
the ignition switch is already replaced by honda . Could it be the the fuel filter??
Old Nov 15, 2003 | 08:51 AM
LudeyKrus's Avatar
It's not the filter.
Sounds like an electrical problem if it started right back up. The steering went limp b/c the engine was dead, so power steering was off.
Check any wiring you can.
Liangma
Honda Civic (2006 - 2015)
Aug 1, 2020 06:41 PM
Blackeris
Honda Civic (2001 - 2005)
Aug 3, 2016 05:38 PM
vietdragontekx
Sep 19, 2012 10:06 PM
salvi2dafullezt
Oct 12, 2009 03:01 PM
giff74
Dec 6, 2003 12:25 PM
