using a p28 in h22 lude vtec problems help!!!
Old Nov 5, 2003 | 06:11 PM
JDMBB2's Avatar
Default using a p28 in h22 lude vtec problems help!!!
i just swapped in a jdm h22 in my 92 prelude si and i am using a p28 ecu and it runs like crap when i hit vtec. instead of giving me power it bogs down and it kind of sounds like its either spitting to much fuel or not enough but you can definitly tell when vtec kicks in. and thier is also no check engine light need help
Old Nov 6, 2003 | 06:23 AM
JDMBB2's Avatar
Default Re: using a p28 in h22 lude vtec problems help!!! (jdmh22lude)
should i use a p13 or i also heard that a p72 will work good also
Old Nov 6, 2003 | 06:35 AM
Jason kiDD's Avatar
I use a stock p28 without any problems. But then again my setup may be different from yours.
Why not get the p28 chipped, it should still run great and will be cheaper than any of the two options you listed earlier..
Old Nov 6, 2003 | 07:12 AM
see_our_vtec's Avatar
Default Re: using a p28 in h22 lude vtec problems help!!! (Jason kiDD)
get a usdm p13. and you will love yourself for it.
when doing a swap. get the right ecu that is designed for your motor. sure a p28 will work. but it doesn't control the aib's. thus limiting power. and also smacks rev limiter at 7300ish. plus it was made for a civic with smaller injectors. the pulse and percentage may be slightly off.
Old Nov 6, 2003 | 08:13 AM
Daboi630's Avatar
are you using a STOCK p28? if you do i believe your not getting enough fuel and your butterflies arent opening stated in the above post.
get the right ecu, p13 or get your p28 chipped by a REAL shop. none of that ebay stuff.
Old Nov 7, 2003 | 07:55 AM
chidoks's Avatar
butterflies are not opening...p28 doesnt have butterfly controls...take out your butterflies or wire an msd switch to open your butterflies
Old Nov 7, 2003 | 04:15 PM
tuan...'s Avatar
Default Re: using a p28 in h22 lude vtec problems help!!! (JDMlude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote">get a usdm p13. and you will love yourself for it.
when doing a swap. get the right ecu that is designed for your motor. sure a p28 will work. but it doesn't control the aib's. thus limiting power. and also smacks rev limiter at 7300ish. plus it was made for a civic with smaller injectors. the pulse and percentage may be slightly off.</TD></TR></TABLE>
u can get a p28 to do w/e u want it to. thus adding the iab's and remapping it to fit an h22 specs. redlines can be set at w/e u want. also a usdm p13 dont have the hondata options, whats an ecu w/o hondata?
Old Nov 7, 2003 | 06:39 PM
Default Re: using a p28 in h22 lude vtec problems help!!! (h22poweredgsr)
you can't get a p28 to do **** without the hondata unit. thats the thing. i've been referring to the p28 that he is using as a "stock p28". personally i think the p72 is the better hondata unit. however they are allmost identical in most aspects.
Old Nov 8, 2003 | 04:34 AM
chidoks's Avatar
i have a p28 chipped to h22 specs...it runs it just like a chipped p13 would...the only thing it doesnt have is the butterfly controls....but i took out my butterflies so it doesnt really matter
Old Nov 8, 2003 | 06:18 AM
c1civic's Avatar
so hows a p72 do without hondata
Old Nov 8, 2003 | 08:31 AM
Default Re: (c1civic)
without hondata. do not use anytyhing but a p13. there is a dyno chart of the p72 vs the p13 in stock form. i think joel(satan srv) posted it not too long ago. both the p72 and p28 will fall on it's *** because of the butterfly valves.
Old Nov 8, 2003 | 10:13 AM
Jason kiDD's Avatar
Default Re: using a p28 in h22 lude vtec problems help!!! (chidoks)
What is the name of the program, and what are the specs??
Old Nov 8, 2003 | 01:57 PM
tuan...'s Avatar
Default Re: (JDMlude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote">without hondata. do not use anytyhing but a p13. there is a dyno chart of the p72 vs the p13 in stock form. i think joel(satan srv) posted it not too long ago. both the p72 and p28 will fall on it's *** because of the butterfly valves.</TD></TR></TABLE>
wat do u mean they both fall on their face cus of the butterfly valves?? the p72 comes w/ iab's so it woudlnt matter. the reason it lagged is due to the fact that vtec kicks in earlier on gsr's then they do on h22's. but overall the p72s make more peak power.
btw, there was a guy awhile back selling ecus for 100bucks. i think he had p72's mapped for an h22 and it cost like 25bucks more. not bad considering p13's go for like 200 or more..
Old Nov 8, 2003 | 03:06 PM
Default Re: (h22poweredgsr)
h22: vtec 5000, iab's ~4600
b18(c1(:vtec 4500, iab's~6000
it falls on it's *** because it's only using 4 of the runners up to 6000. so it's choking in vtec.
Old Nov 8, 2003 | 03:11 PM
tuan...'s Avatar
i see, i thought it was cus the cams on the h22 are bigger and have longer durations then the gsr cams. and if u use the p72 it treats the h22 like its a gsr cam. mabye its like a h22 cam in a gsr? (hypothetically speaking) correct me if im wrong, i dont care.
Old Nov 8, 2003 | 03:13 PM
the reason it falls on it's *** is because it makes it's power lower. thus the reason the iab's are there sooner. it needs that air at a lower rpm to make that mid ranger power. whereas the gsr doesn't. it's like puting a hifh flow cat on a stock exhaust. it's just restricting it.
Old Nov 8, 2003 | 09:51 PM
hybrid_KJ's Avatar
You can make a p28 open butterflies without Hondata. Any chipped p28 can do it you just need to add some extra stuff at the ecu. If anyone wants a p28 setup to run a prelude and operate the butterflies message Kenji.
Old Nov 8, 2003 | 10:06 PM
satan_srv's Avatar
P28 = 1.6 litre motor 240cc injectors
H22a = 2.2 litre motor 290cc injectors
37.5% bigger displacement, only 21% bigger injectors
Simple math says you are about 16% short on fuel
ouch. I feel sorry for your combustion chamber.
Old Nov 9, 2003 | 06:38 AM
chidoks's Avatar
Jason, I am running a JUN H22 Program on my p28...
Vtec kicks in at 4400rpm
Redline is at 8500rpm...
It pulls really hard.... Vtec kicks in too early for me though...gotta get a vtec controller.... I have a skunk 2 chip that i think would be a lot better though... Vtec kicks in at 4800rpm, redline is at 8500rpm... I would swap that chip on there but I dont know how to solder... The ecu was chipped by PYR racing
Old Nov 9, 2003 | 08:29 AM
Jason kiDD's Avatar
Hmm sounds interesting.. And isnt the chip socketed, you should be able to just pull out one and put in the other.. ??
Old Nov 9, 2003 | 03:11 PM
chidoks's Avatar
dont know...never opened an ecu b4...might be
Old Nov 9, 2003 | 06:37 PM
hey joel. nice calculations and all. but you are leaving out injector cycle and duty. so it could either be closer or worse.
Old Nov 9, 2003 | 07:21 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote">hey joel. nice calculations and all. but you are leaving out injector cycle and duty. so it could either be closer or worse.</TD></TR></TABLE>
like i said, simple math.
I don't get what you are saying. The ecu sends the same pulse width regardless. What does duty cycle have to do with it.
Old Nov 9, 2003 | 08:51 PM
Jason kiDD's Avatar
Default Re: using a p28 in h22 lude vtec problems help!!! (satan_srv)
Again I run a stock p28 with no problems...
Old Nov 10, 2003 | 06:29 AM
the injectors. they pulse a certain length every time...............also they only "Inject" a certain percentage of fuel. when you are stock. you are not maxing out your injectors. on the stock ecu they run at a certain percentage of their overall cc. ie 73% injector duty. the injectors are only pulsing 73% of their maximum potential. so 290x.73=211.7 i'm not saying 73% is our injector duty. but i'm saying that they don't max out the injectors in stock form. so theoretically. there could be more of a difference in fuel maps between those ecu's than what meets the eye. because not all honda's have the same injector duty%
do you get what i'm saying now?
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
H22hatchin
Nov 10, 2008 07:00 PM
dek1mfk
Dec 11, 2006 12:22 PM
black92lude
Aug 15, 2005 12:21 PM
prjctCIVIC
Jun 9, 2002 02:57 PM
