Header install problems
Old Nov 6, 2003 | 06:52 AM
lenn's Avatar
Default Header install problems
Hey guys, i was trying to install my DC CC headers this morning on my 97 SH... I soaked all the bolts in WD40 overnight so the bolts on the head came off pretty smoothly.... i didnt have any problems until i started to work on the bolts connected to the cat.
Turns out theres so much rust on them that i cant even feel/see the threads anymore, i tried using a box wrench and a rubber mallet with no results. If i take it to a shop... am i safe to assume that they will cut the studs off? and if they do, will i have problems mounting the flex pipe later? Anyone have any idea how much it will cost me?
I also need some tips with removing the bolts to the mounting bracket, the one thats between the 4 and the 2. There is little space under the car, is working with an extension the only way? Almost all the bolts seem to be seized... its a 8 year old car.....
Thanks!
Old Nov 6, 2003 | 07:38 AM
AndyD's Avatar
Default Re: Header install problems (lenn)
Hey man, I had an issue with mine too...but mine is a 1992 Prelude...so you cna imagine how bad they were.
I got mine off using the Craftsman socket set that is specifically used for stripped bolts. Trust me...this socket set is worth EVERY PENNY!!
I then disconnected the downpipe from the upper portion of the header. I then pulled the entire exhaust system with cat and downpipe down. Then I soaked the bolts on the cat....waited a few minutes and then used the socket wrench with a breaker bar. All came off with a little persuation.
Hope this helps
Old Nov 6, 2003 | 07:55 AM
lenn's Avatar
Well my bolt isnt stripped, the problem is that there doesnt seem to be any thread on the stud... so a socket set wont really help...
How did you get into the tight space to remove the "down pipe" portion?
Old Nov 6, 2003 | 08:06 AM
Daboi630's Avatar
yes. just keep trying. its a pain. a shop will do it for you, maybe $50 to change out headers and no i doubt they will cut the studs off.
Old Nov 6, 2003 | 08:30 AM
AndyD's Avatar
Default Re: Header install problems (Daboi630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">
yes. just keep trying. its a pain. a shop will do it for you, maybe $50 to change out headers and no i doubt they will cut the studs off.</TD></TR></TABLE>
$50??? I was quoted $130
Old Nov 6, 2003 | 09:12 AM
preluda92's Avatar
They had to slice the studs on mine. The exhuast place were I took it had a huge assortment of bolts and stuff so they just slapped in some new ones.
Old Nov 6, 2003 | 09:26 AM
Wiseguy619's Avatar
Maybe you could buy a high flow cat, it will come with new bolts.
Old Nov 6, 2003 | 11:39 AM
Daboi630's Avatar
Default Re: Header install problems (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
$50??? I was quoted $130</TD></TR></TABLE>
local shop in houston did a header swap in a GSR for $60. so i guess around $50, but $130?!?!
Old Nov 6, 2003 | 11:49 AM
sigfan2340's Avatar
I used this stuff called PB Blaster. You can buy at almost any autoparts store. Let it soak in for 20 min, try it, spray some more on it and try again. This should work.
Old Nov 6, 2003 | 12:26 PM
lenn's Avatar
PB blaster? I'll give it a shot if i can find it..... if it doesnt work out.. i figure i'll torch it out myself... even though i dont have any experience... i guess its a good time to learn.... i got quoted "about $60 a bolt... but i gotta look at it first" from a local shop... so you figure it wont be much different if its a siezed bolt or a mushed up molten one....
Old Nov 21, 2003 | 08:58 PM
Muckman's Avatar
Moderator in Chief
Default Re: (lenn)
Installed a Kamakazi Header on a friends Prelude SH today. Same problem with the stripped front cat bolts. I used these to remove the stripped nuts after I heated them up with a torch and it worked wonderfully.
Craftsman Bolt-Out Damaged Bolt/Nut Remover Set
Old Nov 21, 2003 | 09:14 PM
lenn's Avatar
hey, thanks for the suggestion, but problem isnt that the bolt is stripped, but the stud that has so much rust that there doesnt seem to be any thread on it....
the bolt is basically seized, not stripped.... would the craftsman work on something like this?
Old Nov 22, 2003 | 01:20 AM
2+2=5's Avatar
Default Re: (lenn)
hack it off and drill it out, it just takes time
Old Nov 24, 2003 | 06:10 AM
Muckman's Avatar
Moderator in Chief
Default Re: (lenn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lenn &raquo;</TD></TR><TR><TD CLASS="quote">the bolt is basically seized, not stripped.... would the craftsman work on something like this?</TD></TR></TABLE>
Yes. Go to Sears buy the small propane torch and that kit. You need the #7 -12mm socket. I found it best to take the cat and header off in one peice so you can get a big breaker bar on it by taking the 3 bolts of the rear of the cat - exhaust side (much easier than the front 3). Heat up the nut and get a big breaker bar, 18". Have a friend stand on the header so it doesnt flip over and pry the focker off with #7. Came off for me like butter when I had spent hours soaking it in PB blaster, heating it, and stripping it from repeated attempts with the breaker bar and a 6 pnt 12mm socket.
Old Nov 24, 2003 | 06:25 AM
577HondaPrelude's Avatar
Default Re: (Muckman)
those bolts on the cat have a habbit of doing that, I ended up braking 2 of them in half when I was trying to take them off. I just ended up getting a new Heigh-Flow cat. Good luck getting them off, and let us know what "trick" if any works for you.
Old Nov 24, 2003 | 06:46 AM
KENLUDE97's Avatar
Default Re: (57STS)
Get that car a little higher in the air and get a pry bar on there... And screw the rubber mallet and use a BIG steel hammer. Those bolts are ON there. And that PB power Blaster stuff is great!
It could not hurt to heat the bolts up with a Propane torche...
Old Nov 24, 2003 | 11:00 AM
lenn's Avatar
yea... the next plan of action is to take it to a friend's shop.. see if they'll do it for free... if not.. then i'll MAP torch it... then wack it a coupl eof times... sooo.... as for things i've tried already.....
WD-40 for 3 days... didnt do anything
PB blaster for 2 days.... ditto...
hammer and wrench.... ditto....
250 ft lb electric impact wrench.... broke the wrench after 1.5 hours... but it DID work for the mounting bracket bolts that connects to the head.... well one of them...
gonna go out and buy a larrge breaker bar.... would 2ft be considered large? hmm....
Old Nov 24, 2003 | 12:56 PM
Behan's Avatar
Default Re: (lenn)
i used an angle grinder to notch the nut, then used a chisel to break it free while a friend held the bolt with a set of vice grips.
Old Nov 24, 2003 | 01:35 PM
laughinxxx's Avatar
New User
Default Re: (93preludevtec)
You could just get a test pipe, slap it onto the DC header, and bolt the whole unit up to the head and exhaust. by pass the cat all together.
Nipsey Hussle
Nov 15, 2005 08:37 AM
madlion
Oct 13, 2004 03:45 PM
TeGGY_LS
Jun 8, 2004 11:24 AM
miguelsanroman
Aug 9, 2003 02:59 AM
Agent STFU
Jul 24, 2003 11:09 PM
